Results 1 to 10 of 16
- Jun 2013
- 2
June 16th, 2013 08:10 PM #1Hi guys need ur help..
im planning to buy honda fit soon gusto ko ung unit na yan dahil kmukha xa ng jazz, tipid sa gas, maporma at of course affordable xa compare to jazz..I've seen in cebu ranging 180k to 260k ung price pasok xa sa budget ko na 200k but I'm thinking in negative side na surplus xa baka mhirap ung parts nya o mabilis xa masira at baka di din tatagal ung unit mismo. I need ur advise guys..
June 16th, 2013 08:43 PM #2
June 16th, 2013 08:47 PM #3
Fit and Jazz ay iisa lang, the term FIT is used by Honda in their market abroad for the Honda GD. in asian market ang tawag sa GD ay Jazz ang tawag (same chassis code parin naman Honda GD). afaik, same engine ng local and surplus means no problem for spare parts..yung nga lang dahil ang mga surplus ay RHD converted to LHD e dun ka magkakaproblema sa mga pang-ilalim niyan. lalo na paghindi maganda ang pagkaka-convert nung surplus unit.
June 16th, 2013 09:37 PM #4
June 16th, 2013 10:20 PM #5
Imho, sakit sa ulo converted. Ewan ko lang ngayong mga panahin na ito kung mas available parts. Si erpats dati bumili ng van na toyota tpos pinaconvery every now and then fabrication or hirap humanap ng surplus.
Sent from my GT-I9300 using Tapatalk 4 Beta
- Nov 2011
- 473
June 16th, 2013 10:33 PM #6
- Oct 2011
- 86
June 17th, 2013 08:17 AM #8May 4wd fit (surplus) dito? I remember when I went to Russia a couple of years ago. First time ko nakakita ng awd fit dun at sobrang naamaze ako.
Sent from my Nexus 4 using Tapatalk 2
- Jun 2013
- 2
- May 2009
- 93
June 17th, 2013 11:58 AM #10You will not have any problem with the parts since its Honda..common problems I heard is the transmission (surplus kasi) and the quality of conversion from left to right hand drive.
The biggest headache you will encounter is you can not register this in Luzon unless you have proof of custom payment. Ito ang first document na hahanapin mo.
Goodluck..
im planning to buy honda fit soon gusto ko ung unit na yan dahil kmukha xa ng jazz, tipid sa gas, maporma at of course affordable xa compare to jazz..I've seen in cebu ranging 180k to 260k ung price pasok xa sa budget ko na 200k but I'm thinking in negative side na surplus xa baka mhirap ung parts nya o mabilis xa masira at baka di din tatagal ung unit mismo. I need ur advise guys..[/QUOTE]
high idle RPM at engine start
