The Crosswind, Adventure and Innova have fender-type intakes that will allow you to ford water that is almost hood deep. The Crosswind XUV has the highest clearance of the three. The difference amongst the three is that in the Adventure and Crosswind, if you leave the car to sit in a flood, there's less electricals and electronics to wreck.
The Avanza has a grille scoop. And it's lower.
The Spin, nobody has a Spin, yet. But it'll be lower.
The level of flood you can ford in a Crosswind or Adventure is stupid. Stupid meaning that if you ford the deepest flood that they can cross, you are in danger of wrecking the entire car ( alternator shorting, compressor gumming up, fuse boxes soaked, interiors destroyed, etcetera).
Just because you technically can does not mean you should. Always remember that.
