Results 1 to 10 of 14
January 23rd, 2009 06:17 PM #1
Saw this sa comparo ng topgear. 2.0 altis vs Lancer Ex.. 2.0 altis has paddle shifts that rotate with the steering wheel while the lancer has fixed ones...
Any feedbacks sa mga nakatry..
January 23rd, 2009 11:18 PM #2
for me, mas ok yung fixed kasi kung rotating, the person would not be sure if he/she is going down or up shift while steep cornering. at least sa fixed, alam mo na right would be up and left is down shift.
my 2 cents.
January 23rd, 2009 11:35 PM #3
I have driven cars with paddle shifts...
It's better if its fixed. Just like indicator signal toggles, its easier to use when its always in the same position all the time.
January 23rd, 2009 11:40 PM #4
i would like it fixed. if it was with the steering wheel, you might lose your sense of direction. worse you might mistake it for a horn button!
- Oct 2008
- 944
January 24th, 2009 12:07 AM #5though the rotating is nice, fixed parin po bet ko
ang masama kasi sa rotating pag hindi na centered ang alignment ng manibela mo after your abuses eh mahirap na malaman shifters hehe
i dont usually see people shifting gears while turning, mostly alam ko before at after. neither do i. pero kung effortless steering at kailangan mo magshift while turning eh ok naman siguro sa palagay ko rotating
January 24th, 2009 06:27 AM #6
its all preference anyways fix or rotating paddle shift, golden rule in racing is keep your hands on 9 and 3 degree. what happens when your on a counter steer and needs to shift? then you'll need to move your hands to shift, the rotating paddle eliminates that and keeping your hands in a right position even in a lock to lock position.
January 26th, 2009 10:06 AM #7
January 26th, 2009 10:14 AM #8
I'd go with fixed paddle shift. I could lose orientation when taking a sharp curve.....
7404:laundry:
January 26th, 2009 02:18 PM #9
Driven both. Rotating paddle shifters for me.
It teaches you the best practices of driving... keeping your hands in the 9 and 3 o'clock position of the wheel. Besides, I don't see any reason to shift while the steering wheel is 180-degrees or more in either direction.
January 26th, 2009 03:14 PM #10
Even though I've never tried paddle shifters, I think I'd go with the FIXED ones. Why?
1. Baka nga magkamali pa ng pindot kapag wala sa center position ang manibela.
2. Baket, yun bang kambiyo sa gitna ng driver at passenger, umiikot din? hehehe...
3. Para consistent, yung mga light and wiper-washer switches/levers, fixed, e.
4. Kung kailangan mag-shift while turning, pwede naman isang kamay lang ang nasa manibela (usually)... YMMV.
My 2 cents...
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
