Just want to correct a notion. Numbers between diesels, NA gas engines and turbo gas engines are deceptive.
Diesels dont have a flat torque curve. They dump all their torque at 2-3k rpm then it rapidly goes down from there. Same for their hp. Thats why diesels rapidly lose steam at 3.5k and above rpm and their red line doesnt even hit 5k rpm. No fun at higher rpms.
The power and torque curve for a NA(naturally aspirated) gas engine is different. The torque rises from idle to about 4.5k-5k peak torque. Hp rises from idle as well and matches the torque peak. Hence you feel (and actually do) get more power at higher rpms where the "fun" is. Most fun at high rpms but you have to find a way to keep the engine in that rpm range or powerband. Loved by purists.
A turbo gas engine is even better if you like the feel of "torque shoving you into your seat." Good turbo gas engines have a FLAT torque curve that hit their peak below 2k rpm and stay flat till about 5k rpm. Hp will rise from idle all the way to right before red line. These engines give the best "shove" but they have lower redlines that NA gas engines and dont sound as good though. But they easily make the most HP per liter of displacement and are easier to tune.
