Results 11 to 17 of 17
August 30th, 2008 06:00 PM #11
Note that on-paper power doesn't always translate to on-the-road power, though... In testing, the Ford Ranger's torquey engines are still the cream of the pickup crop (even against the Navarra)... wider powerbands, kasi. Nissan's new YD engine is rather peaky.
September 1st, 2008 03:42 PM #12
i agree, on paper lang maganda basahin mga bigger numbers, iba parin ang test drives.
daing factors nga,e..
September 2nd, 2008 11:58 AM #13
like the 2.2l CRDI Engine of Santa Fe, it is punchy form 0-50kph, but lags at top end.....hope to rechip the ECU ( if possible ) for a longer power bond.
but that small engine can match most 2.5-3.0l CRDI of other make.
September 2nd, 2008 12:36 PM #14
Kevin Limjoco of C!Magazine chipped his. Says the acceleration times went from around 11 seconds to the mid-9's from 0-100 km/h. But his chip was really expensive. The Unichip will also work for your ride, and at 30,000 pesos, is about half the price of the common diesel chips on the market. The only disadvantage is that you'll have to leave the car at Speedlab for two or three days for installation and tuning, since it's not plug-and-play like the diesel chips... if the plug-and-play option is available for the Santa Fe, it'll cost another 20-30k.
September 2nd, 2008 06:28 PM #15
September 2nd, 2008 10:23 PM #16
malaking factor din yung 5 speed AT sa acceleration, fully equipped talaga ang sta fe, 2.2 VGT na plus 5 speed AT pa.
kung fuel effiecieny di kaya mas matipid ang non vgt? kasi at low speeds sisipa agad ang turbo, unlike sa non vgt hi revs lang gagana, kaya sa stop and go traffic mas matipid ang non VGT,
sir niky, chip guru, Ive read most of your post reagrding chips and lpg conversion, balak ko kasi bumili ng chip din for my diesel DID, kaso yung nakita ko hindi yung kinakabit after the ecu, but sa fuel rail kinakabit (plug and play din, no wire cutting), sa engine bay kanakabit sa socket daw ng fuel rail. may difference ba yung ganitong chip ang yung unichip?
- Jan 2008
- 18
September 2nd, 2008 10:32 PM #17to everybody ,
thank you for your reply and comments. this thread is very informative indeed, more power!
