ÓT: Ano mga sasakyan ngayon na naka:
1. Chain Drive?
2. Belt Drive?
SUVs, AUVs, MPVs, Pick-ups!![]()
Cguro naman Cars or Sedan bihira lang.TY.
1. Chain Drive?
2. Belt Drive?
The Crosswind is timing gear, not chain.
Mitsubishi gas engines are chain.
Modern timing belts last around 60-100,000 kms. They usually give you no trouble if you follow the change interval. Some manufacturers still use them because they're quieter than chain drive.
The nice thing about the clackety clack of timing chains. If it gets even louder, then you know it's time for replacement.
Personally, I haven't seen much difference between the two in practical use, as long as you do maintenance regularly. I've had to replace the timing belt on my Lynx at around 60-80,000 kms... but I also had to have the timing chain tensioner replaced on the Sentra at around 60,000 kms.
Yes, the chain is definitely safer. Yes, it costs a bit less to maintain. But no, it's not completely maintenance free. You still have to follow similar intervals, otherwise you risk breaking the chain. (I know of two or three instances of chains breaking from my time on the Nissan boards. It's much, much rarer than timing belts stretching and breaking, but it still happens.)
AFAIK belt is more economical to operate because is lighter to spin than chain thats why most engines use timing belt.
timing belt driven valve train has its merits:
1- it is lighter
2- it is quieter
3- when it is time for periodic maintenance, the timing belt and associated parts are external and accessible
timing belt driven valve trains have disadvantages:
1-car owners usually don't maintain their cars as what is recommended by the manufacturer
2-when it breaks, it usually don't give warning telltale signs except the mileage(don't rely on this specially on city driving) and the engine is on clock hours not miles incurred.
3-most shops and so are the car owners are not aware of the MAW (might as well parts) like the camshaft oil seal, crankshaft oil seal, timing belt tensioner, timing belt idler, timing belt driven water pump. they were installed on the same hour, same day, incurred the same mileage, exposed to the same environment. other than that, no car was designed to last forever.
sabi sa akin ng mechanic pag naka-overhead cam sigurado timing chain or belt ang gamit...
pag hindi naka-overhead cam, timing gear ang gamit, me push rod at rocker arm...
tama ba ito?
They usually are but it's not a given. Some more modern pushrods use a timing chain... but the pushrods we have locally are typically timing gear driven.
hi tnx to all reply to this thread,, as im reading all your reply, chain or belt doesnt much concern while chosing a car if you are aware of your maintenance. any of the two can fail anytime..? cost of changing a belt is not too much, unless pag naputol na saka mo lang papalitan at may kasama ng ibang parts na papalitan.. tama po ba?...
Chain is better, naputulan nako ng belt sa L300, hindi biro ang gastos...
Gear is king, old isuzus use this, sabi nung isang naka isuzu na kilala ko, nasisira din daw, pero sigurado mas mauuna masira yung sasakyan bago yung Gear.hehe
Both could fail at any time, but you're talking a 1 in 1,000,000,000,000,000 chance (chain) versus a 1 in 1,000,000 chance (belt) within the first 40,000 kilometers.Chain failures are such freak occurences that you can usually get it replaced under warranty if it happens. (Tensioners, no. Chain, yes)
If you change your belt around 10,000 kms before the change interval, you're okay. Those belts are designed to last a long time... I know some people who've gone 20,000 or 40,000 kms extra before changing, but I don't suggest you do this... as it's dangerous.
Safest is a timing chain engine that's non-interference. Which means the valves and piston will never make contact, even if the chain breaks.
Ultra-safest is a rotary... which has no valves. You can rev them to kingdom come and nothing will break... at least not until the oil rips itself to shreds and the whole thing overheats. Of course, the apex seals are a pain in the butt and fuel economy sucks... which is why only one company uses rotaries, nowadays.
mura lang bro...nasa 3k to 5k pag palit ka timing belt...ung orig dapat buy mo para sure...thnx
rotaries are actually a misnomer. technically the rotors rotate at an eccentric path, not a real circle so there is still some side loading that will ultimately limit RPMs but yes you are correct that before that happens it's usually the apex seals or engine ancillaries that give up the ghost first.
