Page 72 of 80 FirstFirst ... 2262686970717273747576 ... LastLast
Results 1,421 to 1,440 of 1594
    #1421
    Sweet, but that's not a win for the single-speed transmission but for the electric powertrain overall.
    Jul 2013
    #1422
    Just sharing... I never imagined this day would come in my lifetime (sa PHL)...
    Went our for lunch with 3 new employees... used the extra car which was MT...
    Guard went to our table as car needs to be moved (may aalis)
    Nag-uunahan yung 3 to present themselves to do it for me. Gave it the keys to one of the guys, then bumalik sya sa table after less than 5 minutes...
    "Sir, manual pala yung car mo, di ako marunong"
    Then the other 2 also told me, "sorry Sir, AT lang po kami natuto mag drive"
    While moving the car, naisip ko lang na wow... 20 somethings who can no longer drive MT cars...
    #1423
    Soon, mutants will be born with right foot only.[emoji13]
    Apr 2014
    #1424
    Anti theft. Hehe
    It is a dying skill. Soon those who mastered MT will become legends.
    for those driving the a/t wigo, what's the lowest gear option of the car?
    i'm not familiar w/ the vehicle and a lady friend is asking me about it. she's a rookie driver and she's asking for tips for inclined driving.
    #1426
    i'm not sure what you're asking for, but you can lock it for "2" and for "3", or go full 4.
    Jan 2009
    #1427
    "D" will let the car go from 1st gear to 4th gear.
    "3" will let the car go from 1st gear to 3rd gear (ie. D3 on Hondas). Can be used on extended uphill drives to prevent gear hunting
    "2" likely means it is locked on 2nd gear. It's typically used in cold climates to help prevent wheel-spin on snow
    3 and 2 can also be used if you need engine braking on long downhill drives
    ah so "2" is the lowest gear in the wigo for driving on steep roads .
    all our a/t vehicles are tiptronic now so they don't have the "2" or "3" gear options. and like i said, i haven't driven nor ridden shotgun in a wigo yet so i don't really know its gear lay outs.
    i remember our old gd jazz had an "L" gear even though it was already equipped w/ a "manumatic" feature.
    thanks for clarifying bros!
    Jan 2009
    #1429
    I wouldn't put it like that. Rather, "2" is the lowest selectable or lockable gear. The lowest gear is still technically 1st gear, which is available in "D" and "3" modes, but it operates in full-auto and hence, you can't lock it on 1st gear.
    #1430
    from what i understand, "2" means car gear will be either 1 or 2 only. on "3", the choices of the car will be 1, 2, or 3. on D4, it will be full-range 4 speed.
    once, i absent-mindedly left it on "2", and i was wondering why napaka-bagal ko sa daan, kahit tinatapakan ko naman ang silinyador...
    but the car seems intelligent naman.
    going up our steep parking ramp, with the stick on full D4, the gear is still on 1, even as the rpm is beyond the shifting point. i can feel when it shifts, kasi.
    #1431
    I have observed that it is better to just leave the car in D and just modulate the throttle to optimal output. Even with our old slowpoke Jazz 1.3L AT, I didn't have any issues going up steep building ramps if I put it in D. This is for the usual automatics.
    For DCT, the car will be intelligent enough to stay in second gear or third gear when traversing steep ramps. For CVT, just keep the throttle steady and the tranny will put you in the right gear.
    Jan 2009
    #1432
    Maybe. But I have yet to see an A/T that has a 2 or L2 which cycles through 1st gear.
    If you read almost any owners manual, 2ng gear is typically used to get out of slippery surfaces, like snow or sleet. The reason being, 1st gear has too much torque in it so you will have to do extra work managing the gas pedal to avoid slipping. 2nd gear inherently reduces the torque available at the wheels and it makes it easier to accelerate without slipping.
    If 2 or L2 cycles through first gear, it won’t make any sense under these situations.
    #1433
    If 2 or L2 cycles through first gear, it wonÂ’t make any sense under these situations.
    Believe me, in dry snow or icy surfaces, no amount of torque will help once you lose traction from your tires, even if you are driving an AWD or 4x4 vehicle. Such conditions are even worse for RWD vehicles. In snow surfaces, proceed only when you can establish grip from all 4 tires. Once you lose traction or grip, ease on the throttle and steer the car to slow down the slide until such time you get traction back. Don't ever, ever brake or your vehicle will become a battering ram to the vehicle in front of you.
    Jan 2009
    #1434
    Going up a short incline in a parking structure is totally different from an uphill drive that spans hundreds of meters.
    In a short incline, you’re likely doing no more than 20 to 30kph. “D” is fine as it probably won’t shift up beyond 2nd gear.
    But on long and winding uphill highway the likes of Kennon Road, you’re likely doing 50 or 60., at least. That may cause your transmission to oscillate between the last two gears. This is especially exacerbated when the vehicle is loaded to capacity. “3” or “D3” will prevent the transmission from going to overdrive, only to lose power and then shift back down again, wash rinse, repeat.
    Jan 2009
    #1435
    No, you use 2 or L2 when starting off from standing still. It is not a cure all but it is there to help anyway.
    #1436
    It entirely depends on the vehicle you're driving and the road condition you're facing. No amount of help from your tranny can offer if you can't even get your vehicle out of its place like a small/medium car trapped in about a tire's diameter of snow.
    Jul 2019
    #1437
    a/t for me
    Sent from my CLT-L29 using Tapatalk
    Jul 2019
    #1438
    Most of my friends tend to go with A/T due to heavy traffic considering their cars are mostly used for city driving. Same for me, but also because of ease of use.
    #1439
    Quote Originally Posted by rhapsody9 View Post
    while i admit, AT offers a more comfortable drive, "i feel more secure, driving my MT".
    la lang..
    i have both. MT innova and AT innova.
    #1440
    MT on Mondays and Sunday.
    AT on other days and saturdays
    Mas fun yun MT above 3k rpm.
Battle of the Transmissions: M/T vs. A/T
