Results 851 to 860 of 1594
- Jul 2013
- 56
July 27th, 2013 09:15 PM #852
August 4th, 2013 09:53 AM #853
a/t for leisure and heavy traffic driving, m/t for kick ass driving
but i'm comfortable with both. the only obvious difference is that a/t maintenance is much costly
making a call thru your celfone and eating your fave snacks are acceptable BUT texting while driving is a big NO NO !
- Jun 2013
- 2
August 8th, 2013 02:20 PM #854to sum it all
flexibility and control MT
convenience AT
other factor car sharing mas flexible ang automatic
mas madali ipahiram ang AT
MT cars are cheaper
better fuel economy which is dependent on driving style
theoritically maintenance lamang ang MT
hirap lang talaga masyadong pampered tayo dahil technology is offering convenience kaya nagtatabaan tayo
MT offers konting additional calories burn
pero minsan convenience has its perks
kunwari nasprain ang left ankle mo sa basketball. pwede ka pa rin magdrive ng AT
- Jul 2013
- 56
August 20th, 2013 09:58 PM #856Usually less yung powerloss sa MT vs conventional AT because MT transmissions are directly connected to the drive wheels while conventional AT transmissions use a torque converter. The torque converter itself can be thought of as joint between the engine and an AT transmission. Imagine the connection between engine and transmission as 2 shafts, in between these shafts is a thick fluid. When the shaft from the engine spins, the fluid also starts to spin, this then makes the shaft going to the transmission also spin.
While this allows an AT to make smooth starts without need for a clutch, spinning the fluid in the torque converter wastes engine power when compared to the direct connection of a MT. This wasted power is power that could have gone into making the car accelerate faster, hence the advantage.
That's why some cars like Fords with "Power Shift" transmissions instead use a dual clutch transmission. Which in effect it is a MT transmission that is operated via computer so that it acts like a conventional AT. The downside of these however as it won't be as smooth as a conventional AT.
One final note is that all transmissions are not made equal. Each transmission can be made to give more acceleration or more top-speed, this greatly affects acceleration and fuel consumption. top-speed setup transmission usually give better fuel consumption than acceleration setup transmissions, because of this some AT transmissions are given topspeed oriented gearing compared to their MT versions to match their fuel consumption, in exchange for slower acceleration.
Hope that helps but correct me if im wrong.
August 20th, 2013 10:11 PM #857
- Jul 2013
- 56
August 21st, 2013 10:23 AM #859
VinFast VF 3
