Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Jun 2010
    Hi guys which one do you prefer in overall performance?
    Posted via Tsikot Mobile App
    Price Comparison:
    Mazda 3 1.5 V Skyactiv 4DR(Sedan)__________P 945,000
    Mazda 3 1.5 V Skyactiv 5DR(Hatchback)_______P 948,000
    Corolla Altis 1.6 V_________________________P 999,000
    Engine Comparison:
    Mazda 3 1.5 V Skyactiv - SKYACTIV-G In-line 4-Cylinder DOHC, 16 Valves - 112ps / 6,000rpm Torque - 144NM * 3,500rpm
    Toyota Corolla Altis 1.6V - DUAL VVTI-l, 4-Cylinder In-Line DOHC 16 Valve - 122ps / 6,000rpm Torque - 154NM * 5,200rpm
    Transmission:
    Mazda 3 1.5 V - 6-speed automatic transmission
    Toyota Corolla Altis 1.6V - "7-speed" CVT
    Mazda 3 1.5V - Curb weight - 1,254 kg(sedan) 1,264 kg (hatchback)
    Toyota Corolla Altis - Curb weight - 1,265 kg
    Aug 2014
    can i ask for something?
    mas matipid ba sa gas ung cvt ng altis vs sa manual counterpart niya?
    Don't expect too much in terms of performance with either cars, unless you opt for the 2.0L versions. The compact cars these days are getting bigger and heavier but engine output are still within 120hp. The 2.0L models offer better power-to-weight ratio at 150+hp for a small increase in weight (1300+ kg). The Civic FB 1.8S offers good power output for its weight (140hp * 6300 rpm, 177 Nm * 4300 rpm, 1228 kg).
    If you want a more sporty ride for less price, go with the Fiesta Ecoboost (125hp * 6000 rpm, 170 Nm * 1400-4500 rpm, 1135 kg).
    Between the 2, I would get the Corolla Altis 1.6V. Sa Mazda 3 lineup only the DOS LITROS is I think worth getting (pero mahal).Kung yung 1.5 lang, wag na lang bitin...
    I have not driven both but based on the figures provided, as both cars are about the same in weight, the Altis offers higher output (122hp vs 112hp) but the Mazda3 gets it max torque earlier (3500 rpm vs 5200 rpm). However, in normal driving conditions, we barely hit the 5k rpm mark unless we floor that pedal in a highway. 3500 rpm can be easily reached with short spurts. All these boil down on how well you feel the car in a test drive. Go try them out first before deciding on buying one.
    There's a Comparo Review between these two cars in Top Gear Magazine June issue.
    They picked the Mazda 3 1.5V as the winner.
    They actually find that the 1.5V variant more enjoyable to drive than the 2.0S without the i-stop start/stop function.
    And there's no stability control in Toyota Altis, only ABS.
    Personally, I will pick the Mazda 3 over the Toyota Altis.
    Apr 2008
    Can I suggest Nissan Sylphy ?
    Jan 2014
    If given the two choices I'will go for the altis,remember it's a toyota
    what's your budget?
    if your budget is 1M
    how about the ford ecosport
    Mar 2004
    ^^^ You're saying to get the Altis because it's a Toyota and then suggest a Ford?
Altis 1.6v or mazda 3 1.5at
