Results 11 to 19 of 19
June 8th, 2015 02:56 PM #11
the XE 1300 cc variant i think, consumes more gas than the 1.6 GLi variant.
suggestion din sa TS, baka you may also want to consider the 91-92 small body variant na GL. yung sobra sa budget mo, allocate mo na lang for repairs.
Toyota Corolla Small Body For Sale Philippines - Find 2nd Hand (Used) Toyota Corolla Small Body On OLX
Toyota Corolla Small Body 90 For Sale Philippines - Find 2nd Hand (Used) Toyota Corolla Small Body 90 On OLX
1989 Toyota corolla small body For Sale Philippines - Find 2nd Hand (Used) 1989 Toyota corolla small body On OLX
June 8th, 2015 02:58 PM #12
Additional choices:
Makinis pa....
Toyota Corolla All Power For Sale Philippines - Find 2nd Hand (Used) Toyota Corolla All Power On OLX
Eto makinis din.... ganda pa ng kulay...
Toyota Corolla small body 89 Model For Sale Philippines - Find 2nd Hand (Used) Toyota Corolla small body 89 Model On OLX
eto, maganda pa din...
Toyota corolla 1990 model small body For Sale Philippines - Find 2nd Hand (Used) Toyota corolla 1990 model small body On OLX
- Apr 2014
- 231
June 8th, 2015 03:27 PM #13
- Apr 2014
- 231
- Apr 2014
- 231
June 8th, 2015 05:13 PM #16
mukhang ok naman..... nababaduyan lang ako dun sa pulang drum brake....
check mo the following:
a. leaks sa ilalim and under the engine bay
b. electricals
c. aircon
d. suspension
e. condition ng radiator
f. temperature while driving.
b. electricals
c. aircon
d. suspension
- Apr 2014
- 231
June 8th, 2015 05:18 PM #17
June 8th, 2015 05:35 PM #18
1.6 GLI bro. All power.. With ALTIS stock mags. Silver in color. May mga scratches pero no major dents, buo pa ang kaha.. latang lata/sariwa. When it was sold in October 2014, all tires (including reserved) are newly-replaced (in May 2014); with new 4SM motolite enduro battery; newly fixed aircon, brand new evaporator, alternator, exhaust fan.. with seat cover.. pioneer head unit.. duck tail spoiler.. etc.
June 8th, 2015 06:45 PM #19
Checking for oil leaks : Checking for oil leaks | How a Car Works
Also check for water leaks. It means either sira na ang hose o pasira na ang water pump.
Electricals :
a) Using a tester, check the electrical output sa battery while engine is turned-off and while running.
b) check all lights, wipers, radio
c) check condition of power windows, central locks, etc.
d) check condition of engine bay wires and high tension wires.
Aircon:
a) Have the car idle for a while with aircon off. Cabin should be cool enough, depending on the thermostat setting.
b) Rev up the engine while A/C is on, dapat hindi nagbabago ang buga ng hangin.
c) Check for sounds coming from the engine while AC is on.
Suspension:
a) Check for sounds while driving
b) Silipin ang CV boot
c) Turn the steering wheel while stopped. Dapat walang sound.
d) Drive the car and feel every sound that comes from underneath.
e) Dalahin mo sa lubak lubak na daan and sa may mga humps to check for shocks condition. Pag may bounce, sira na ang shocks.
f) Silipin mo condition ng joints and bushings kung kaya mo.
g) Kung kakayanin, try mo ihataw oto ng hanggang 90 kph to check for faulty axle bearings.
Radiator
Turn the engine off and cool it down for around 15-20 minutes, then open the radiator cap. Inspect the radiator cap and check the condition dun sa nguso. Dapat walang libag o langis. Pure coolant lang dapat makikita mo.
Check condition ng coolant sa reservoir.
Temperature
Observe the temperature gauge while idling, without AC, with AC and while driving....
Others:
a) check sound while idling baka butas na ang exhaust system.
b) check idling kung erratic... baka sira na o madumi ang throttle body.
c) check for engine bay squeaks baka palitin na ang mga belts.
d) get maintenance record if available.... things to look for are timing belt replacement, water pump replacement
e) rev it and see if there is smoke coming from the tail pipe.
f) check to see if there is smoke coming out of the tail pipe while idling.
g) check condition of tires
h) check condition of flooring baka nabubulok na. mas maganda kung masilip mo yung ilalim.
Madami pang checks dyan that I really cannot enumerate here. Kung bagito ka lang, try to bring a friend who knows about cars or a trusted mechanic.Last edited by 1D4LV; June 8th, 2015 at 06:56 PM.
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
