To be sure, just check the manual. If it requires premium, most likely 95RON. Wala naman ata common petrol engine that requires higher than 97RON.
If it does require 95RON, just use Petron XCS or kung tipid, UniOil 95RON with discount from S&R card.
Aggressive ka ba sa expressways? Do you have any plans to test how fast your ride can do?
Yes I’ll check out the manual again.
I’m not usually that aggressive, depends on the car that I’m using. Well, fast but not aggressive, if that makes sense.
I’ll probably test it at some point but after that high speeds are gonna be few and far between…
