Results 11 to 14 of 14
May 25th, 2022 03:56 PM #12
I would pick the HR-V just because it is newer and it is more likely to be a better value now than a used XV.
The looks (both in and out) of the HR-V are superior, imho. However, the XV is AWD and will likely be a better drive overall. Safety features will probably be similar but the Honda Sensing tech on the HR-V is probably better than the older iteration of Subaru Eyesight from the XV.
- Jan 2007
- 2,577
May 25th, 2022 06:28 PM #13May BS din Porsche. I'm sure you know of the IMS/RMS issue on 996/997s. Then there's a problem pa with the cylinder lining because Porsche thought alusil was too expensive and they made a cheap-o version of it (lokasil) that degrades and causes cylinder scoring.
If you remember that video of a 996 spewing all sorts of smoke I'm starting to wonder if this was the cause...
May 25th, 2022 09:53 PM #14
Dati kasi, Sojitz Corp ang distributor ng Geely locally, ngayon Geely Motor Philippines Corp....
BYD Philippines
