Results 31 to 40 of 49
Tsikot Member Rank 3
- Dec 2002
- 551
July 15th, 2006 12:47 PM #31dudee,
almost all new diesel powered will be crdi. It started with the hyundai starex and continued to its other models, then the isuzu alterra, next were the toyota models innova, hiace, fortunner, and last were mitsubishi with their gen 3 Pajero and gen 3 strada.
In the hilux 2.8, frontier 3.2 and strada 2.5 engines. The hilux and frontier are naturally aspirated while the strada has a turbo and an intercooler to maximize the power. If you would put the turbo and intercooler on the hilux and frontier syempre lalakas ang hp nila A naturally aspirated 2.5 mitsubishi engine only give 72hp when it is equipped with a turbo it reaches 88hp, but when you include the intercooler it rises to 100hp.
Sa frontier ok lang naman 3.2 yung engine, no problem its even better in the long term di kaagad malalaspag because you dont need to rev it high all the time unlike a smaller engine you usually want to rev it high to run fast. Sa strada nga yung evolution version nila they use a 3.5 dohc turbo intercooler gas engined.
- May 2006
- 424
July 15th, 2006 08:45 PM #32Originally Posted by johnart
Matic ang Frontier, strada is Manual. Mas alaga ang Frontier sa itsura kaysa Strada...
What would be your pick? I'm still searching for other pick up pa nga.
July 18th, 2006 06:05 PM #33
strada is more MACHO and tends to hold a higher resale value against the frontier, daming frontier ngayon! mataas yang 2000mdl at 500T.
oh, check out my ad nga pla
http://4x4ph.com/forum/index.php?act=ST&f=14&t=7085&
- May 2006
- 424
July 18th, 2006 06:15 PM #34Di ba mas malakas sa Diesel pag may TURBO ang engine ? or is it the other way around?
- Aug 2004
- 108
July 18th, 2006 07:03 PM #35Originally Posted by av427
- May 2006
- 424
July 18th, 2006 08:10 PM #36Originally Posted by Jai
baket pala walang sumisingit na RANGER?
- Dec 2002
- 551
July 18th, 2006 11:17 PM #37Originally Posted by Dudee
My pick is still the strada iba yung tipid ng 2.5 vs the 3.2 engine. Yung turbo does not use more diesel it uses the exhaust to generate the extra power. In short it maximize the engine's potential. Yung lang nga if you have a turbo you need to idle the engine to cool down the turbo and religiously change the oil. Because if the turbo is hot and you shut off the engine immediately the bearings may seize and with the oil if you neglect to change it often the turbo may break because of lack of lubrication.
I own a strada 2002 model its now at 23k km at around march this year I was able to get a top speed of 160kph driving at star tollway so engine power is just right. And before I was able to load sacks of gravel which cause my rear bed to fall reaching 6 inches to the ground. Drove it to tagaytay at a speed of 100kph. Couldn't drive faster becasue it may be unsafe to stop and turn with a heavy load.
- Mar 2006
- 106
July 19th, 2006 05:56 AM #38Originally Posted by Jai
Bro, ang alam ko yung 4x4 na Frontier is ranging between 500-580 thou, pa IM naman kung san yan nakalista, ang mura sobra ng benta nila, good buy yan
Original Price nyang 4x4 is around 780 thou nung 2001, di ko lang sure kung malakas nga lang sa gas yung 4x4 version, although mukha nga based from yung ibang nakadrive na nung 4x4 pero shempre expected na din yun.
My brother and I both own a Frontier na 2001 4x2, sabay pa kami bumili halos months lang pagitan Kakabenta lang nung kanya sa 425 thou, wala pang 2 weeks ago, mataas na din kse ang mileage more than 100k na ang tinatakbo. Gusto nyang car pampamilya na talaga. Wala pa shang natitipuhan ipalit. Gusto nya yung Rav 4 saka CRV before pero back out sha nung nalaman nya na malakas din pala sa gas. Naghihintay pa rin sha ngayon sa market ng malaki pero matipid. Sobrang tipid kasi talaga yung 4x2 na Frontier, pati nga ako ngayon sobrang nagugulat kse dati nung 2001-2004 di ba wala namang ganong issue sa gasolina pero ngayon shempre iba na, presyong ginto na. Na-compare ko din sha dun sa Jazz idsi namin eh mas matipid pa din yung Frontier pick up kaya madalas talaga yun pa din ginagamit ko miski bago yung Jazz. Lalo na ako, taga Alabang pa ko kaya layo talaga ng biyahe ko everyday.
- May 2006
- 424
July 19th, 2006 06:21 AM #39Originally Posted by johnart
- Dec 2002
- 551
July 19th, 2006 09:42 AM #40Originally Posted by Dudee
correct or just idle the car before shut down like it you travel in the city 1 to 2 mins but if you travel over 100kph around 5 mins cooling down just to make sure. Mahal kasi ang isang bagong turbo charger
Xiaomi E-Car
