Results 21 to 30 of 62
- Jan 2006
- 56
March 31st, 2013 02:28 PM #21
March 31st, 2013 08:36 PM #22
i have a taxi unit accent crdi. at 130,000 km ang pinalitan ko palang is auxilliary fan assembly worth P2700(oem).suspension parts still intact.
regular maintenance na lahat like replaced/changed brake pads(P500.00), fuel filter every 20k km(P800.00 oem), air filter (P140), aircon filter ( P140), clutch disc (P2150 oem), pressure plate (P1800 oem), release bearing (P630 oem). and egr cleaning every 20k km DIY
- Jan 2006
- 56
March 31st, 2013 08:49 PM #23San gasolinahan ka sir nagpapa refill ng diesel?
Sent from my Lenovo P700i using Tapatalk 2
March 31st, 2013 09:54 PM #24
- Apr 2004
- 653
- Aug 2018
- 9
August 23rd, 2018 07:32 PM #27
Quite an eye opener as I always thought the Accent CRDI would represent value for money due to the cheaper fuel and relatively better FC. I think I'll stick with my Altises then.
August 23rd, 2018 07:44 PM #28
August 23rd, 2018 07:46 PM #29
August 23rd, 2018 08:21 PM #30
I think this has something more to do with the Accent being a Korean vs Toyota, hindi diesel vs. gasoline. Both cars have their merits, I own an Accent diesel & I like the looks of the Altis. Your choice of engine will depend a lot on how you plan to use it. If it is for short city stop & go, the Altis will be the logical choice. If you go long, continuous distances most of the time, then the Accent diesel it is for you. Diesels need a 20 sec warm up & a 1 min cool down, more oil & more frequent pms than the gasoline. Diesels will take you longer on a full tank than the gasoline & the engine of the accent is quiet for a diesel. And if you do have a diesel used in the city, you will have to take it out for a long 40 min drive every 2 weeks at least, just to keep the turbo healthy. John Cadogan has more info in YouTube.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
