Results 21 to 30 of 62
- Jan 2006
- 56
March 31st, 2013 02:28 PM #21
March 31st, 2013 08:36 PM #22
i have a taxi unit accent crdi. at 130,000 km ang pinalitan ko palang is auxilliary fan assembly worth P2700(oem).suspension parts still intact.
regular maintenance na lahat like replaced/changed brake pads(P500.00), fuel filter every 20k km(P800.00 oem), air filter (P140), aircon filter ( P140), clutch disc (P2150 oem), pressure plate (P1800 oem), release bearing (P630 oem). and egr cleaning every 20k km DIY
- Jan 2006
- 56
March 31st, 2013 08:49 PM #23San gasolinahan ka sir nagpapa refill ng diesel?
Sent from my Lenovo P700i using Tapatalk 2
March 31st, 2013 09:54 PM #24
- Apr 2004
- 653
- Aug 2018
- 9
August 23rd, 2018 07:32 PM #27
Quite an eye opener as I always thought the Accent CRDI would represent value for money due to the cheaper fuel and relatively better FC. I think I'll stick with my Altises then.
August 23rd, 2018 07:44 PM #28
August 23rd, 2018 07:46 PM #29
August 23rd, 2018 08:21 PM #30
I think this has something more to do with the Accent being a Korean vs Toyota, hindi diesel vs. gasoline. Both cars have their merits, I own an Accent diesel & I like the looks of the Altis. Your choice of engine will depend a lot on how you plan to use it. If it is for short city stop & go, the Altis will be the logical choice. If you go long, continuous distances most of the time, then the Accent diesel it is for you. Diesels need a 20 sec warm up & a 1 min cool down, more oil & more frequent pms than the gasoline. Diesels will take you longer on a full tank than the gasoline & the engine of the accent is quiet for a diesel. And if you do have a diesel used in the city, you will have to take it out for a long 40 min drive every 2 weeks at least, just to keep the turbo healthy. John Cadogan has more info in YouTube.
That makes sense. Higher elevation has lower atmospheric pressure and even if the cooling system is...
