Results 21 to 30 of 70
- Apr 2008
- 6,235
October 21st, 2020 12:14 PM #21Though siguro considered best in class na ang Brio, medyo outclassed ang Brio kapag kinumpara sa Almera. I've driven a friend's 1st gen Brio Amaze and its fine if you will be alone. The old 1.3 makes it a pocket rocket, though I hear the new 1.2 of the 2nd gen is a bit down on power. If you are around my height (5"10), there is hardly any legroom left at the back.
The Almera on the other hand is famous for class leading interior space, and it is one class higher than the Brio.
Sent from my SM-G965N using Tapatalk
- 54,271
October 21st, 2020 12:26 PM #22
- Apr 2008
- 6,235
October 21st, 2020 12:43 PM #23
- 54,271
October 21st, 2020 12:52 PM #24
- Apr 2008
- 6,235
October 21st, 2020 01:08 PM #25
- Feb 2014
- 2,711
October 21st, 2020 01:31 PM #26
- 54,271
October 21st, 2020 01:35 PM #27
- Feb 2014
- 2,711
October 21st, 2020 07:15 PM #28
there's the almera drum, with bearing and studs. instead of having a separate hub like on most cars. maybe a cost saving measure
- Nov 2009
- 3,509
October 21st, 2020 09:04 PM #29^Mechanically they are the same being held by 4 bolts on the suspension, but maintenance-wise, this drum-over-bearing design is better than bearing-over-hub. Aside from ease of inspecting the bearing condition everytime the brake is serviced, the stand-alone bearing is cheaper than sealed hub-bearing assembly. and uh. its easier to replace a broken stud.
- Feb 2014
- 2,711
October 21st, 2020 11:00 PM #30
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
