Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 70
    Apr 2008
    #21
    Though siguro considered best in class na ang Brio, medyo outclassed ang Brio kapag kinumpara sa Almera. I've driven a friend's 1st gen Brio Amaze and its fine if you will be alone. The old 1.3 makes it a pocket rocket, though I hear the new 1.2 of the 2nd gen is a bit down on power. If you are around my height (5"10), there is hardly any legroom left at the back.
    The Almera on the other hand is famous for class leading interior space, and it is one class higher than the Brio.
    Sent from my SM-G965N using Tapatalk
    #22
    Quote Originally Posted by GTi View Post
    i'd really love to get an almera.
    but i am wary of the tibay factor...
    i do not want to be a frequent visitor to the casa's talyer.
    Apr 2008
    #23
    I have a friend who drives a 2015 Almera. Got it brand new. As far as I know, she has so far only done routine maintenance on it.
    #24
    what's the odometer reading, kaya?
    there have been posts earlier, wherein i got the impression that the current almera may not be as trouble-free as desired.
    Apr 2008
    #25
    Not sure sa exact reading, but as far as I know, below 50k. Used for beater car duty, but is not an only car. [emoji23]
    Feb 2014
    #26
    rear wheel bearing premature failure. but it's cheap to fix.
    weird design. apparently the bearing is pressed into the brake drum. maybe this design places more load on the bearing
    whatever it is it's a minor issue
    #27
    Quote Originally Posted by Vodka View Post
    my old 1997 sentra had this un-explainable squeak in the right rear. had it opened... and closed. other than the sound, nothing else until the day i sold it.
    i wonder...
    Feb 2014
    #28
    there's the almera drum, with bearing and studs. instead of having a separate hub like on most cars. maybe a cost saving measure
    #29
    ^Mechanically they are the same being held by 4 bolts on the suspension, but maintenance-wise, this drum-over-bearing design is better than bearing-over-hub. Aside from ease of inspecting the bearing condition everytime the brake is serviced, the stand-alone bearing is cheaper than sealed hub-bearing assembly. and uh. its easier to replace a broken stud.
    Feb 2014
    #30
    any ideas why it's failing prematurely on the almera? i.e. failing even before the front wheel bearings
Honda Brio V / RS CVT vs Almera 1.5 E A/T
