Results 11 to 13 of 13
- Jul 2003
- 14
July 15th, 2003 04:20 AM #11How do you insulate against road and engine noise?
Put sound deadening to roof, doors, floor, trunk
basically take everything out and install deadening, you can even
install a second layer to have better sound proofing.
- Jan 1970
- 164
July 15th, 2003 02:32 PM #12How about noise that goes in through wire access points through the firewall and transmission access areas?
- May 2004
- 1
May 15th, 2004 09:28 PM #13meron yan sa mga audio shops sa banawe. sa galant i think 2700 is good for 2 front doors pero di ko sure. [/B]
I'm not familiar sa Banawe. Do you know any specific audio shop that sells dynamat?
How about Peel & Seal, is it available here also?
Thanks.
high idle RPM at engine start
