Results 1 to 7 of 7
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 11th, 2008 08:48 AM #1I have a defective right tweeter. Pls recommend a replacement. I prefer silk dome if possible. Its going to be mounted on the dash board so best if grey color to match the dash.
It will be matched with a 6.5 inch midbass from CDT. Powered by an amp rated at 50x2 at 4ohms. The amp is underrated a lot (old school amp) so its actually pumping out more than 50 watts.Last edited by userfriendly; May 11th, 2008 at 08:56 AM.
May 11th, 2008 09:42 AM #2
for tweeters, i like the sound of lansar and a/d/s. they are not expensive but sounds great IMO.
at your rating, i would not have an idea if they have it. pero with the color, i do know lansar has the grey. im not sure what model they have.
May 14th, 2008 01:48 AM #3
Try the Aura Sound MR1 tweeter color gray-ish black featuring 1" silk-dome tweeters with a neodymium magnet system and dual-mono, two-way MRX passive crossovers. MR1 has a frequency response of 3kHz - 20kHz, is rated at 50W continous/120W peak power into 4 ohms, with a sensitivity rating of 87dB.
- Jun 2006
- 2,605
May 14th, 2008 08:59 AM #4ano comments niyo sa:
DLS TN25 tweeter
Blaupunkt Velocity tweeter
Crystal CSC tweeter
Paki bigay ng price range at saan meron sa QC area.
May 14th, 2008 09:19 AM #5
Blaupunkt ang dala ng C3 diesel sa may a. bonifacio cor C3.
kaya lang wala silang tweeter lang. set na included sa separates. nasa 7K to 9K.
- Jun 2006
- 2,605
May 25th, 2008 06:41 PM #7syempre pair ang replacement.
Na postpone ang pagbili ko. Baka next month na lang. I'm thinking of installing 2 set of tweeters in front. 1 set of main near the midbass and a 2nd set on the dash as image tweeters. My passive crossovers has this function. Ano kaya ang tunog?
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
