I have a defective right tweeter. Pls recommend a replacement. I prefer silk dome if possible. Its going to be mounted on the dash board so best if grey color to match the dash.
It will be matched with a 6.5 inch midbass from CDT. Powered by an amp rated at 50x2 at 4ohms. The amp is underrated a lot (old school amp) so its actually pumping out more than 50 watts.
Try the Aura Sound MR1 tweeter color gray-ish black featuring 1" silk-dome tweeters with a neodymium magnet system and dual-mono, two-way MRX passive crossovers. MR1 has a frequency response of 3kHz - 20kHz, is rated at 50W continous/120W peak power into 4 ohms, with a sensitivity rating of 87dB.
Na postpone ang pagbili ko. Baka next month na lang. I'm thinking of installing 2 set of tweeters in front. 1 set of main near the midbass and a 2nd set on the dash as image tweeters. My passive crossovers has this function. Ano kaya ang tunog?
