Page 3 of 3 FirstFirst 123
Results 41 to 60 of 62
    Mar 2004
    Quote Originally Posted by rapunzalan.ncpi View Post
    i would recommend growl audio. have one installed yesterday with tv plus. Android pa sya so i just hot spot my phone and use wase there also, and check my farms in Clash of kings pag traffic hehe
    Nice! Magkano inabot? Kasama ba pati yung TV headrest?
    Apr 2014
    nagpa install ako ng abs cbn tv plus sa manila then pagdating ko dito sa davao wala na ng signal. Any recommendation sa mga master? Kailangan ko pa ba mag change ng sim dahil hindi compatible sa location?
    Apr 2010
    Quote Originally Posted by maverick74 View Post
    It might be that digital tv in PH is not mature yet and hindi pa nagrorollout ng stations outside of Metro Manila, even within MM mahina pa signal in some areas as I've read
    Where do you put the antenna? I'm getting a DTV box for a room, and in the process may try DIY'ing it in the car. I am eyeing the "black box" or the RCA DV1402.
    Anong power supply ginagamit niyo? I have an unused CDRKing UNIVERSAL CAR ADAPTOR 1800MA adapter, trying to bring down the cost by not having someone install it.
    Quote Originally Posted by ParticleX View Post
    nilagay ko antenna ko sa back part ng oto, sa loob. altis ang sasakyan.
    on the power adaptor, pinutol lang yung stock tv plus power adaptor, tapos naka tap sa HU.
    Jul 2016
    sir did you try to rescan? As far as I know kasama na ang Davao sa coverage ng TV Plus..
    noticed ko lang din sa TV plus if mabilis ang takbo parang nawawala ang signal...
    davao is covered by ABS-CBN TV Plus. probably all you need to do is to do a rescan.
    you do not need to change the sim.
    Mar 2003
    sir particle gumamit din po ako ng rca na brand 5 volts. . gumawa lang ako ng wire usb to DC connector. then plug sa usb lighter from cdr king 1 amp.
    Sent from my SM-G9287C using Tapatalk
    Apr 2010
    Already got the tv+ to work when parking, pero hindi pala pwede when the vehicle is moving... what should i do?
    Apr 2009
    sir dalhin mo lang sa magaling na technician may paraan sila dyan. meron silang nilalagay na sariling switch parang bypass yun. if you live close to the south(Binan) dalhin mo kay BP audio. mga 30 minutes job lang yan.
    Sent from my GT-I9300 using Tsikot Forums mobile app
    Apr 2010
    Quote Originally Posted by poknet View Post
    wanted to do it myself sana para matuto rin. may nakita na akong link dito sa Tsikot, yung green wire daw pero wala kasing wire pinouts yung radio sa body and sa manual nya so i cannot be sure: Video Shuts-off when vehicle starts moving. kung binaklas ko yung panels, mga magkano sisingilin nila?
    Quote Originally Posted by 1D4LV View Post
    my tv+ unit works even while running 100 kph sa skyway. may mga deadspots lang talaga.
    panong di gumagana yung sa iyo while moving?
    Image says:
    Caution: Driver is prohibited by law from viewing a video signal on any in-dash monitor while the vehicle is in motion
    Working sya pag naka Park mode and/or handbrake is up (will double check later) but outside of Park, the message appears. Sound is unhampered though. Wala akong external displays as of the moment aside sa head unit.
    Image says:
    disclaimer: i only use it if i have a passenger, otherwise, i am on radio/spotify mode.
    not sure with your case bro.... it could either be on your connections though. yung sa akin kasi simple lang ang connection. power is tapped sa HU din, antenna is at the back of the car.
Tv plus ready head unit
