Page 1 of 3 123 LastLast
Results 1 to 20 of 57
    mga pare,
    I need your advice and recomendations on setting up a mobile office inside my vehicle. What I plan to do is fit a laptop alongside a portable printer inside a SUV.. any other suggestions?
    For internet, I plan to use my cellphone as a modem to connect to the net. as for other techie stuff, medyo malabo nako dun.. what other hardware can you guys recommend? planning to use this kasi sa Batangas-Laguna area and I really need the convenience of a mobile office.
    Thanks!
    Dec 2003
    buy an inverter, a larger one that can handle up to 200 or 400 watts, make sure u have a capable 12v line to power the inverter. then u can run almost anything na including laptops, printers, TVs, ps2 etc
    Mar 2005
    use wireless networking:
    for bluetooth:
    I would assume that you had this setup already with a bluetooth-enabled laptop & cellphone. why not look for a bluetooth printer, I think HP has one, though i'm not sure if it's portable. the advantage of this you can just put your printer anywhere inside the car (or at the back of the suv, suv's have 12v adaptors at the back d'ba)
    if you insist on a portable printer,
    buy the wireless d-link hub/router with a print server. connect your printer with the d-link router and place it anywhere inside your car. Now, this is the catch: the d-link router is a dsl router. since you're gonna use your phone as internet connection, you wont need the d-link dsl router feature. (I only suggested this bec. this is the cheapest wireless router in the market with built-in print server).
    if your laptop is wifi-enabled as well as bluetooth enabled. use your bluetooth as you normally use it connecting to your phone internet. then use the wifi to connect to the d-link and you have a wireless "car" network.
    one advantage of this wifi-system is that when you park at wi-fi enabled zones like coffee shops & restaurant, just buy a wifi card, scan the air, input your card password and then surf and print. hehehe
    another advantage is if you want to impress a girl friend who happens to also own a car and a wifi laptop, tell her to park near you and connect to your "wireless car network" and let her print to your printer. now, that's extra service hehehe
    hey thanks for the suggestions... I'd like to add more toys for the Mobile Office and going wireless is definitely interesting as well as its advantages hehehe.
    Nearest base ng Office ko is in Cabuyao, Laguna. But I'll be definitely mobile and move around the Batangas area too that's why I'm setting up this Mobile Office / Ride. Hmmm.. Wi-Fi Ride... I like that!
    Feb 2005
    If you're within the coverage of wirless providers when you're inside your mobile office or you would operate mostly in these tpes, you can go wireless. However, if you would be on trips, go for the mobile phone often. You would just need a USB mobile phone adapter. Easy enough to buy (unit dependent).
    For the printer, the best portable printer is the HP DeskJet 450. It can run on either AC or DC. The battery life is a decent 3 hours or so. I've been using for a year. This printer is USB-based and weighs less than three pounds. PPGM is quite good. So far, no complaints. I also have the bluetooth printer but it's heavier compared to to 450 and does not have batteries. The 450 is thin enough to fit inside an expandable Targus bag.
    BBimmer's suggestion is the first thing you need to do: buy an inverter.
    Good luck.
    May 2005
    The HP DeskJet 450CBi InkJet Mobile Printer has a Lithium Ion and has a small footprint. It also has a compact flash drive where you can attach (AFAIK) a compact flash bluetooth transciever. You can also use the CF slot to print pictures from your CF without connecting your printer to your computer.
    If your laptop has bluetooth you are good to go. If not, you would need to purchase a bluetooth dongle for your laptop.
    Feb 2004
    kung marami kang pera, lagyan mo na rin ng fax and dedicated cellular faxline ayos
    andy
    A better space saver would to get an all-on-one printer/scanner/copier/fax machine.
    May 2005
    get the we-roam wireless dsl of pldt ... not as fast as if you have a hard line ... but it's better than using your mobile phone ... not sure if will work in batangas though ..
    may inverter ka na? ask ko kasi the cheapest i saw was a 100 watt unit for P3600 sa sm city carpark cyberzone. need ko din kasi for my laptop. was in singapore airport yesterday and i checked for a laptop car power kit, there is a 90 watt IC regulated unit selling for S$190 (yaiks!) meron din cheap 70 watt unregulated unit selling for S$85, mahal pa din and since unregulated e delikado for a laptop. so i will probably end up using an inverter na din. paki-post naman please where and how much you get your inverter. thanks.
    yebo: wala pa naman. pero I'm surely buying by next week. post ko dito if I find something good and cheap (as if may ganun pa hehehe...)
    ghosthunter: I was thinking of getting the same thing pero wary ako na baka hindi nya kaya yung constant travel. or might as well have it properly secured whenever mobile na.
    Got my Coleman 200 Watt inverter for $19 bucks on sale. Very nice specially when we have a long drive with the GPS and my laptop.
    As for a mobile office, here's my idea.
    Get a mac mini (base price is $499 but upgrade the memory to at least 512mb or 1GB)
    Get a Liliput touch screen LCD and make a custom install:
    Get a canon mobile printer i80 - works both with rechargeable batts or directly in a power source, only 4 lbs Dimensions: 12.4" W x 6.9" D x 2.0" H so it can fit most glovebox compartments.
    And you can get a wireless mini keyboard and mouse with BT.
    airshaq20: excellent suggestions!
    Aug 2004
    where can i buy a reasonably priced inverter? want to bring the ps2 on the road....
    Quote Originally Posted by mrpink
    it will work. weroam rides on the GPRS infrastructure of Smart. so kung saan may signal ng smart, may weroam ka....
    diba silver_corolla?
    Feb 2005
    A buddy of mine and I are thinking of embarking on a project that would rig his SUV with a shuttle PC with a 15" flat screen. May rumble pad pa. Unfortunately, we don't have the time yet on our hinds to plan for this project.
    The Canon i80 is a very good portable printer. However, the hp 450 got a higher overall user rating (7.4) compared to Canon's 6.9. Then again, you can't go wrong with any of these two: light, runs on batteries and good print quality. However, I read somewhere that the Canon i80 eats ink a lot faster compared to the HP's DeskJet 450.
    As for the inveter, if you don't mind locally made ones, you can get them at raon
    Apr 2005
    opps huwag kalimutan baka di kaya ng alternator yun mga inverter ninyo baka kailangan din ipa-upgrade ,
    I would recommend getting a tablet pc instead of a regular laptop (pero mahal na option eto).
    Sa printer I would suggest the HP because cannons (although smaller/lighter) have smaller ink containers and have very expensive ink than HP.
    Sa inverter I have 2 (one on each ride that I use). The earlier model rates 200w and does well. The newer one I got from ALEXAN (in SM) rates at 200w pero seems to overload (baka madaling mag-init) often with the same load of appliance (usually my XDA2 charger). Sa laptop charger wala naman problem. Cost was P1500 to 2500.
    If you want a generic inverter made in Raon, try this ANASCOM, 3rd Flr 545 F. Torres St., Sta Cruz, Manila. Its walking distance sa ilalim ng LRT route in Raon, Quiapo. Tel (02) 733-8185, 8857, 8858, 736-6689. Try if the numbers still work, thier name card I have with me is already 3yrs old. They say they are one of the common suppliers ng inverters ng mga provincial buses (Victory liner) for the big TV and VHS/VCD/DVD player nito. Maybe kaya nila ang PS 2 and an big TV. Cost was P2700 to P10,000 depending on the wattage.
    Alternator capacity could be a problem for cars, but for SUVs and pick-up baka kaya na.
    my 2 cents
    Mar 2005
    sabi ng pldt, as long as there is a signal on your smart celphone, gagana daw ang pldt weroam.
    May 2004
    aside from notebooks and other gadgts na mataas ang price.
    paano yung mga budget meal setup na gusto mag mobile ofc?
    is it possible to hook an old p3 motherboard and put it on a boxed enclosure[for suv]?
    the mini enclosure made of wood will house the cpu, kbrd mouse can be plugged and unplugged anytime can liliput lcd serve as a montior?
    is that possible?
Turning Vehicle into Mobile Office
