Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Jul 2018
    Mga sir, patulong naman po. Ano po kayang magandang brand ng speaker? Around Php 1500-2000 po budget for a pair. May mga nakita ako sa mga shop na Nakamichi, TEAC and Team Lighting Lab, all of them below 2k a pair.
    Sent from my Redmi Note 7 using Tsikot Forums mobile app
    Quote Originally Posted by batang_angas View Post
    i do not think it is so much the speaker's brand, but rather, whether the speaker model matches the sound system's output characteristics, i.e., "are they matched?"
    even the best speaker on the market won't sound well, if its characteristics do not match the sound system's output characteristics.
    The best speakers are that you can afford any given time. If budget is not an issue, some of the people I know spend 6 digits on their car audio sound systems.
    kung gusto mo ng brand recommendation ok sa akin ang ryan audio. may nakita ako sa lazada 6.5 na coaxial 2way 1450pesos.
    Attached Thumbnails Attached Thumbnails screenshot_20200611-202047_lazada.jpg
    Jan 2009
    Get the top 3 to 5 models that's within your budget and check for online reviews.
    The sound quality is also affected by the how well it was installed or placed, quality of the head unit and/or outboard amplifier, and other add-ons such sound deadening.
    Remember that sound quality is mostly subjective.
    matanong pala. anong kotse ba ilalagay?
    ^This.
    My recent speaker journey...
    Had to swap old, torn, too far gone stock speakers. Genuine replacement was ruled out. Wanted some improvement.
    Thing w/ online sourcing, one will leave a lot to guesswork....besides speaker diameter & cost.
    Measured stock ones up, shopped & took the risk. The new speaker depth>stock & the mount holes were off those on the door. A bit of surgery, spacer fab were needed. To retain stock screw mating, the stock housings were cut away from the old speakers....to be adapted to the new. Measured the needed spacers to keep the magnet from touching the door's sheetmetal.
    Pics of the door speaker(JBL) mod below. Luckily for the rears, the Pioneers were a direct, no-mod required fit.
    Old speaker housing cut out from old assembly. White spacer was cut off a sintra board I had laying around.crappy stockJBL mountedBad stock rearsNew Pioneer rear
    ^This.
    uy 6x9s. those could produce decent base but they are getting rarer and rarer as oem. i can only think of the nissan navara having them now as stock..for the fronts hehe.
    when i needed spacers but did not have some. i used folded up cardboard from the box the speaker came in cut as spacers sadnwhiched between the screw hehe. most probably didn't do anything for the sound quality but it prevented the magnet hitting the glass.
    If you want a good sounding and simple car audio setup, you just need the following:
    A decent HU
    A pair of good separates (mids with tweeters plus crossovers)
    A small subwoofer (10”) in a sealed enclosure
    A 4-channel amp
    You can forget about the rears as a properly-tuned system can make the necessary surround experience. Use MDF plywood for speaker spacers and the subwoofer box. If you can spend a bit more for deadening, go for it.
    Budget will be the key factor. You can opt for the affordable models from brands like JBL or Pinoeer. If you want good quality car audio equipment, check out DLS or Focal or Morel.
    ito pasok din sa budget mo for speakers.
    Infinity coaxials. I prefer these two-way rather than three or four.
    Syempre highly subjective ang speaker preference saka ang daming factorsna nakaka affect sa sound.
    Attached Thumbnails Attached Thumbnails screenshot_20200612-103754_shopee.jpg
    Apr 2012
    A decent HU
    A 4-channel amp
    very well said sir[emoji106]
    let me add a good installer if not going the D-I-Y route
    fortunately,
    hindi tayo pihikan.
    all stock is fine with me.
    just how much high fidelity do you need to listen to ted failon and Deo McCalma?
    The cardboard could crumble w/ moisture, sir. I needed some thickness & stability...good thing I had scrap sintra.
    A decent HU
    A 4-channel amp
    +1, bai.[emoji106]. Can't afford the pricier brands[emoji852]...For spacers, I opt for something w/ better water resistance than wood-based boards, esp when done on doors.
    Below was another DIY rehab w/ a bud who handed his old Fort's removed factory sub. This was forced into the 80's stock housing(1st pic shows how bad the speaker was). Definitely not direct fit, but worked nicely. Also replaced a busted relic, vintage USmade Pioneer amp, w/ an affordable newer version. Stock HU has no smartphone connectivity...just settled for a hobo Ugreen USB charger w/ BT-FM transmitter. It's now back to being roadtrip worthy....besides being the old loyal workhorse.
    Jul 2018
    Hobda city type z lang sir. Sira na kasi yung rear speakers nung nakuha ko. Yung isa kenwood (punit na) yung iaa not sure kung anung brand. Head unit ko po is sony xplod 1din.
    Jul 2018
    I think decent naman siguro sir yung sony xplod head unit. Basag na lang talaga yung speakers. I bought the car second hand. Looking for replacement sana. I also saw a pioneer speaker priced at Php 2500.00. I think that would be a good choice also?
    i think most brand new speakers will sound better than your torn old speakers.
    let us make sure the speakers we buy match the output requirements of the head unit.
    my colleague bought a pair of (cheaper daw) local speakers (forgot the name), and was surprised that it sounded so good.
    wala na sana adjustments or mounting modifications, when the new speakers are installed.
    I am not sure if Targa is still available but it was quite good for its price.
    Jul 2018
    Heard of the brand po. Will check if it is available within my area. Planning to get it installed by the shop instead of doing a destroy it yourself. Haha
    kun sa shop i-pa test mo na ng pa test while installed sa kotse mo. these speakers brands have certain characteristics na ikaw lang makakapag sabi kun gusto mo o hinde kapag narinig mo na. kun kasya 6x9 na two way sa likod mo sa akin ok yun generally they give a little more bass vs coax na 6.5inches. kaso kita ko sa lazada shopee parang nasa 2k plus na sila.
    Jul 2018
    I'll keep that in mind sir. Thanks a lot! [emoji4]
Speaker Replacement
