Results 1 to 10 of 32
- May 2005
- 234
April 23rd, 2006 12:59 PM #2
pag gumagamit ka ng mataas na wattage ng sub mo everytime na dumadagundong yung sub mo e kumakain ng kuryente kada dagundong mo. If you install a capacitor it will eliminate ang pag aagaw ng kuryente. kung baga e kada dagundong ng sub mo lumalabo ang ilaw ng oto mo kung wala kang capacitor. kung meron naman e kahit dumagundong ka palagi e stable ang pasok ng kuryente mo kasi kada dagundong e sa capacitor manggagaling ang extra current papunta sa amps mo. sa madali't salita e para syang back up battery para di mag agawan ng kuryente ang sound system mo and the electrical system of your ride.
- May 2005
- 234
April 23rd, 2006 01:30 PM #3Ah ok..Ive seen a lowered owner type jeep that had 2 capacitors..If you happen have a low output amp will this help?
April 23rd, 2006 01:41 PM #4
as far as I know if you have a 800watt system or less e di mo na kelangan nun unless you want to have a bling factor on your ride. pero kung more than 1000watt yung system mo and napapansin mo e nag aagaw ng kuryente habang nagpapatugtog ka e I would suggest to get a 1.0 or 1.2 farad capacitor.
- May 2005
- 234
April 23rd, 2006 03:55 PM #5Just for playing safe if you had a low output alternator would using a capacitor help?
- May 2005
- 234
April 24th, 2006 11:56 AM #7If my vehicle has a low amp output alternator will a capacitor help if i install a high wattage system?
April 24th, 2006 01:36 PM #9
yes it will help. ang capacitor e para mastabilize ang current ng electricity sa system mo kahit na dumadagundong ang system mo. kung baga e para syang extra battery for the quick power surges na kukunin ng amp/sub mo pag dumadagundong. capacitor would store some voltage for that quick surges. and if you're gonna install it make sure you charge the capacitor first before using it...
November 24th, 2006 10:14 PM #10
revive ko lang tong thread na to po...
ano pinakamaganda na pinakamura na brand ng capacitor po?
Traffic!
