Results 11 to 20 of 28
December 18th, 2008 05:46 PM #12
December 18th, 2008 05:53 PM #13
ah..external naman pala. gusto ko internal
iba na yata usapan dito... ang layo na from tv reception.. balik po tayo sa discussion mga sirs.
redwave: sir. hows the reception from your new antenna you purchased from blazed?Last edited by av8or5; December 18th, 2008 at 05:58 PM.
December 18th, 2008 10:21 PM #15
You'd be surprised to know that that is just an ordinary "rabbit-ear" antenna ... but one of the best-looking I've seen.
Kaya kumukurap ang reception ng channel 2 kapag nasa Cavite ka ... because of the frequency of Channel 2 (the lowest on the TV band), you need to extend the antenna to its fullest length. It won't look at its best, but the reception on 2 should be better.
- Sep 2008
- 1,219
January 15th, 2009 06:10 PM #16Sir maganda po ba ang reception nyo maski sa mabuilding? meron po kase binibigay sakin si Jet Circuit na made in taiwan na antena pero may disclaimer agad na mejo blurry.
January 16th, 2009 05:36 AM #17
bro,pag masyado dikit o napaikutan ng building medyo kumukurap, ganun din pag masyado malapit sa LRT/MRT line yun naman po galing taiwan ay hindi ako makapag-bigay ng opinyon, pero may mga nasubukan na ako from taiwan yung dinidikit sa loob sa likod at connected sa 12V, meron din ako nung dinidikit sa labas sa gilid ng kabilaan bubong total apat na sungay meron oto ko, labo pa rin at mukha na ako porcupine hi hi hi...
January 16th, 2009 08:32 AM #18
Hello mga Sirs! Good day! Gusto ba ninyo i-rephrase ang title ng thread na ito?
Since you are talking about "Car Antennas", why don't we change it kung ok lang naman sa thread starter? What do you think po?Last edited by LadyRider; January 16th, 2009 at 08:35 AM.
- Sep 2008
- 1,219
January 16th, 2009 08:19 PM #19
- 299
January 17th, 2009 03:54 AM #20why not try this fractal antenna. yan ang gamit ngayun sa mga cellphones.
The first thing I would like to discuss is a little history, theory, and uses for fractal antennas.
Fractal antennas are a recent discovery. First discovered back in 1988 by Nathan Cohen and later published and patented in 1995. A fractal antenna has a few unique attributes as seen in this definition from Wikipedia:
"A fractal antenna is an antenna that uses a fractal, self-similar design to maximize the length, or increase the perimeter (on inside sections or the outer structure), of material that can receive or transmit electromagnetic signals within a given total surface area or volume."
What exactly does that mean? Well, you need to know what a fractal is. Also from Wikipedia:
"A fractal is generally a rough or fragmented geometric shape that can be split into parts, each of which is (at least approximately) a reduced-size copy of the whole,a property called self-similarity."
So basically, a fractal is a geometric shape that repeats and appears over and over no matter how far out or how far in you zoom magnification. For visual clarification, here is a picture of the patented antenna:
Source: Wikipedia and http://patimg2.uspto.gov/.piw?PageNu...id=US007088965 Patent number: 7088965]
From this website: How to make a fractal antenna for HDTV / DTV plus more on the cheap http://ruckman.net/blog/news.php?item.21.4
HTH
