Results 1 to 10 of 12
May 2nd, 2003 03:59 PM #1
question lang po pwede bang pang dedeaning yun acoustic foam yun nabibili sa truevalue yun 1 side is carpetside the other 1 is parang alumunum. pang seal ko sana sa tapat ng speaker sa loob ng pinto ng sasakyan ko.
jake
May 3rd, 2003 10:53 PM #2
kung deadening...HINDI.
they are usually heavy materials like rubber to "deaden" the material that can distort (?) sounds coming from your speaker. (usually...doors....etc...)
ung acoustic foam...they are used to......hhhmmmm...make the car more acoustic!?!?!?dang....i dont know how to explain it well...
May 4th, 2003 07:55 PM #3
Basically yon acoustic form prevents outside noise (road noise) and heat from entering the cabin. I use this once (pajero) under my carpet. It really minimize road noise especially at the tranny area.
SiRaNeko
- Jan 2003
- 973
- Apr 2003
- 526
May 17th, 2003 06:52 PM #6ano mas maganda gamitin sa floor areas, acoustic foam or flashband which is mix of asphalt and rubber materials?
- Mar 2003
- 81
May 18th, 2003 09:14 AM #7dynamat. here's a background:
http://www.dynamat.com/tech_how_dynamat_works.htm
meron yan sa banawe
- Apr 2003
- 526
May 21st, 2003 10:49 PM #8may nakapagtry na ba using flashband sa floors? how much kailangan to do the entire floor and how long nyo ginawa?
- Apr 2003
- 526
May 25th, 2003 05:58 PM #9Originally Posted by afrasay
^All branches of Jiga Primacy and XM2 lang available :( Is Roadstar good? I want Michelin brand...
Finding the Best Tire for You
