Results 1 to 12 of 12
    question lang po pwede bang pang dedeaning yun acoustic foam yun nabibili sa truevalue yun 1 side is carpetside the other 1 is parang alumunum. pang seal ko sana sa tapat ng speaker sa loob ng pinto ng sasakyan ko.
    jake
    kung deadening...HINDI.
    they are usually heavy materials like rubber to "deaden" the material that can distort (?) sounds coming from your speaker. (usually...doors....etc...)
    ung acoustic foam...they are used to......hhhmmmm...make the car more acoustic!?!?!?dang....i dont know how to explain it well...
    Basically yon acoustic form prevents outside noise (road noise) and heat from entering the cabin. I use this once (pajero) under my carpet. It really minimize road noise especially at the tranny area.
    Jan 2003
    eto rin ba yung insulation foam? parang foam wid aluminum foils?:?
    Quote Originally Posted by buknoy2002
    iba po yan. pang thermal lang po yan.
    Apr 2003
    ano mas maganda gamitin sa floor areas, acoustic foam or flashband which is mix of asphalt and rubber materials?
    Mar 2003
    dynamat. here's a background:
    http://www.dynamat.com/tech_how_dynamat_works.htm
    meron yan sa banawe
    Apr 2003
    may nakapagtry na ba using flashband sa floors? how much kailangan to do the entire floor and how long nyo ginawa?
    Apr 2003
    Quote Originally Posted by afrasay
    sir, how thick yun ginamit mong acoustic foam? nadaan ako sa true value, daming thickness sya available e. yun han gang brand.
    1/2 inch lang enough for you to install the carpet above it.
    Quote Originally Posted by cardsVR
    meron yan sa banawe
    what shop sa banawe? any contact number?
    Dec 2002
    up ko lang, baka meron pa pong maka suggest...
acoustic foam
