Results 21 to 30 of 37
February 1st, 2006 10:43 AM #21Originally Posted by scarab
February 1st, 2006 11:19 AM #22Originally Posted by silhouette
...kaso ni-lock ng mod yung thread niya. di kasi nilalagay contact#.
February 1st, 2006 03:04 PM #23Originally Posted by scarab
- Dec 2005
- 24
February 1st, 2006 09:15 PM #24Mga peeps may amp ako na 1000 watts na 4 channel, drive nya yung sub ko na isa
pwede ko bang gamitin yung ibang channel sa iba pang speakers??? ano kaya epekto
nito? thanks*!
- Jul 2004
- 240
February 15th, 2006 07:22 AM #25Originally Posted by FXT
so why choose 4 channels? because some people run their system in active mode (using active crossovers). By doing this, they would need to power their speaker individually (tweeters / mids).
advantage of going active = more possibility to tweak your sound system by being able to control the cutoff and slope ng tweeters and mids.
my 2 cents
February 15th, 2006 11:28 AM #26
The advantage of 4 channel amp over 2channel is having single amp to power both your front speaker and sub. 2 Channel is used normally to power the front (usually sep) and another mono amp for the sub. Looking at these two set-up, the 4channel is more cost effective.
February 15th, 2006 12:47 PM #27
-sil-
hindi po malakas kumain ng kuryente yung mga amps na yun. pero pag ang whole system mo umabot ng 1000 watts.. better put some capacitors and much better a higher alternator. para hindi ka bitin sa power. dami pa dyan sa kac. pero kung gusto nyo kasi 1 amp system. kunin nyo yung dd c4 (Digital Designs c4 amp) 4 chaneel amp. specs:
2 x 50 + 2 x 100 into 4 Ohms, measured at 12.0 volts.
2 x 70 + 2 x 140 into 4 Ohms, measured at 13.8 volts.
2 x 100 + 2 x 210 into 2 Ohms, measured at 13.8 volts.
1 x 200 + 1 x 420 bridged mono into 4 Ohms, measured at 13.8 volts.
*50 x 2 to power front speakers, 420 mono to drive rear sub(s).
- Feb 2006
- 4
February 19th, 2006 09:08 AM #28mga boss,
just bought a v12 mrv 705 ask lang ako kung ilang set ng speakers ang kay nitong i drive. then ilang watts per channel. thanks
- Jul 2004
- 240
February 19th, 2006 10:50 AM #29SIMPLE ANSWER:
if its 2 channels, it can drive 1 set of speakers
if its 4 channels it can drive 2 sets of speakers
if its 5 channels it can drive 2 sets of speakers plus a subwoofer
etc
NOT SO SIMPLE ANSWER
-It can drive an infinite number of speakers. It all depends on how you wire them such that the load/impedance being seen by the amplifier is within the amps limit
February 20th, 2006 01:39 PM #30
the v12 705 amp i think is 75x4 pero i doubt it... overrated yang amp na yan
high idle RPM at engine start
