kinorek na yata scarab. nakabantay din ako eh. hehe.Originally Posted by scarab
Originally Posted by silhouette
...kaso ni-lock ng mod yung thread niya. di kasi nilalagay contact#.
oo nga noh. meron pang isa, yung kay alex11. though not sure kung available pa.Originally Posted by scarab
Mga peeps may amp ako na 1000 watts na 4 channel, drive nya yung sub ko na isa
pwede ko bang gamitin yung ibang channel sa iba pang speakers??? ano kaya epekto
nito? thanks*!
i think main advantage of 4-channel over 2-channel amps is PRICE. Mas mababa ang presyo ng 4-channel amps as they share a common power supply.Originally Posted by FXT
so why choose 4 channels? because some people run their system in active mode (using active crossovers). By doing this, they would need to power their speaker individually (tweeters / mids).
advantage of going active = more possibility to tweak your sound system by being able to control the cutoff and slope ng tweeters and mids.
my 2 cents
The advantage of 4 channel amp over 2channel is having single amp to power both your front speaker and sub. 2 Channel is used normally to power the front (usually sep) and another mono amp for the sub. Looking at these two set-up, the 4channel is more cost effective.
-sil-
hindi po malakas kumain ng kuryente yung mga amps na yun. pero pag ang whole system mo umabot ng 1000 watts.. better put some capacitors and much better a higher alternator. para hindi ka bitin sa power. dami pa dyan sa kac. pero kung gusto nyo kasi 1 amp system. kunin nyo yung dd c4 (Digital Designs c4 amp) 4 chaneel amp. specs:
2 x 50 + 2 x 100 into 4 Ohms, measured at 12.0 volts.
2 x 70 + 2 x 140 into 4 Ohms, measured at 13.8 volts.
2 x 100 + 2 x 210 into 2 Ohms, measured at 13.8 volts.
1 x 200 + 1 x 420 bridged mono into 4 Ohms, measured at 13.8 volts.
*50 x 2 to power front speakers, 420 mono to drive rear sub(s).
mga boss,
just bought a v12 mrv 705 ask lang ako kung ilang set ng speakers ang kay nitong i drive. then ilang watts per channel. thanks
SIMPLE ANSWER:
if its 2 channels, it can drive 1 set of speakers
if its 4 channels it can drive 2 sets of speakers
if its 5 channels it can drive 2 sets of speakers plus a subwoofer
etc
NOT SO SIMPLE ANSWER
-It can drive an infinite number of speakers. It all depends on how you wire them such that the load/impedance being seen by the amplifier is within the amps limit
the v12 705 amp i think is 75x4 pero i doubt it... overrated yang amp na yan
Ok. Nakabili na ko ng JBL GTO 75.4 II but I have yet to install it.
Ano bang tamag gauge ng power cable na dapat gamitin, gauge 8 ba o gauge 4?
Is there any specific brand for power cable to look? How about RCA cable wire, what should I consider, is there any recommended brand. For speaker wire I heard that ordinary wire will do the job unless gauge is correct. Thanks to your help.
kung gusto mo talaga hindi generic wires and rca, i suggest these brands, lightning audio, scoshe also known as EFX. maganda na yung brands na yan. pag rca's again lightning audio, EFX, alpine, RF rca's
Field Master, power cable kahit mga "generic" ok na, power cables sold in raon to the branded wiring kits, halos pareho lang, same color, same copper stands. Also a generic RCA will do, difference between a branded and generic RCA is negligable.
Most amps can handle 4-8 ohms loads, it's safe to run numbers of speakers as long you're not going over the amp ohms limits, check amp. manual.Originally Posted by gwyneth
