Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Jan 2003
    ....mga bro, ano ba marerecommend niyo na amp to drive my seps? yung malinis talaga tumunog. also, what specs should i look for in an SQ amp?
    ...though medyo budgeted ako, recommend kayo ng medyo branded para mag hunting nako ng 2nd hand.
    Mar 2005
    RF Punch 4004, JBL GTO 75.4, JBL GTO 60.4 (yung brushed aluminum yung cover, new from JBL), DLS CA23, uhm, ano ulit yng seps mo?
    Jan 2003
    ...6" aura seps pre. im still trying to resolve the popping sound coming from the tweets pero feeling ko parang may tama na rin yung amp (the left dBh indicator needle is not moving).
    ...tnx for the recommendations, i'll take note of that. any more audio gurus?
    ...oo nga pala, specs din pala (like 2 or 4 channel, watts per channel, ohms). sobrang baguhan lang kasi ako sa audio (though i admit, the audio bug has bitten me).
    Quote Originally Posted by scarab
    main advantage po ng 4-channel amp is the fade function (from front to back, vice-versa). for instance, may natutulog sa likod, ayaw nyong maabala, pwede nyong i-fade yung sound sa harap lang, para di masyadong malakas sa likod.
    Jul 2004
    Quote Originally Posted by FXT
    i think main advantage of 4-channel over 2-channel amps is PRICE. Mas mababa ang presyo ng 4-channel amps as they share a common power supply.
    so why choose 4 channels? because some people run their system in active mode (using active crossovers). By doing this, they would need to power their speaker individually (tweeters / mids).
    advantage of going active = more possibility to tweak your sound system by being able to control the cutoff and slope ng tweeters and mids.
    my 2 cents
    Jan 2004
    Whether 2 or 4 channel depends on how many speakers you want to drive. Watts per channel depends on how much the speaker can handle (although you can set the gain, someone might change it, like the mechanic's curious assistant).
    Generally 2 channels will power two sets of speakers, left and right. 4 channels can power... you guessed it: 4 sets - Left Front, Right Front, Rear Left, Rear Right. But then there is this concept of bridging, so a 4 channel amp can be wired to power two sets, with higher output. The amp specs will tell you if it can be bridged.
    Power: generally, if your speaker can handle 50W RMS, a 50W RMS amp will do. There are conflicting schools of thought as to whether you can drive it with a 75W RMS or a 35W RMS amp and not have problems, or claim they sound better. If you can audition several amps with your speakers at the store, the better chances of your getting what you want based on hearing preferences. One other thing to make sure is that you are reading the RMS of both the speaker and the amp, and the amp is xW RMS into y channels, where y is the number of speaker sets you want to drive.
    Jun 2005
    budget?
  8. #8
    Old school is the way to go...
    MTX
    Genzen
    Sherwood
    Rockford
    Earthquake
    Autotek
    Lanzar
    Coustic
    Mar 2005
    yes budget.. kung bbili ka na rin ng brand new go AUDIO SYStem.. linis and ganda tumunog
    Jul 2004
    Ride on lang ako dito sa thread na ito. Have to buy amp din soon.
    Ano pag-kakaiba ng mono at stereo amp?
    Mar 2005
    mono amps sir is for subs only... for best power po sya.
    Jul 2004
    Quote Originally Posted by baurtwellXUV
    Thanks BartwellXUV.
    maki-sabit na rin po ako, balak ko rin mag-ampli.
    yung bang nakalagay sa speaker rating na 400 watts max power, RMS po kaya iyon?
    boschmann po ang brand. ilang watts na ampli ang pwede sa kanya?
    thanks.
    Jan 2004
    Quote Originally Posted by zero
    thanks.
    Nope. Check mo na lang sa manual ang RMS rating nyan. Baka overrated pa yung 400.
    thanks.
    depende po, some speakers pareho yung peak and RMS power nila, but most of the time di pareho, so check nyo na lang yung box or manual. as for the amp to drive them, more power the better, para di ma-stress out yung amp nyo which results in clipping and possible damaging your speakers. i-match nyu na lang po yung power ng amp nyo sa RMS rating ng speakers. depende rin sa type of music that you listen to. kung mahilig kayo sa classical, jazz, or vocals where you go from soft to loud a lot, then more power is needed to accomodate the dynamics of the songs/music.
    Jan 2003
    ...budget is 5k max (kaya 2nd muna). kaya i need your suggestions for brand and specs. keeping my eyes posted dun sa ad section sa KAC and i have 2 amps here na ipang sa-swap ko sana.
    Mar 2005
    -scarab-
    may nakita ako sa KAC na audison na amp. ok din po yang amp na yan. linis tumunog.
    amps na magaganda for sq: mabigat sa bulsa.. hehehe!
    sinfoni
    twister/audio system
    steg
    dls ultimate series
    alto mobile
    old skul soundtream
    old skul ppi amps
    Jan 2003
    ...any comment bout this amp, saw it at KAC.
    Pioneer GM2200. 130w rms x 2, 300w rms bridged * 4 ohms. RCA or DIN Input
    Mar 2005
    meron dun yung f340 na alpine good price na sya...
    May 2004
    bart, malakas ba kain nyan sa kuryente? i mean kailangan ba mag upgrade ka ng alternator to feed that little monster? sori men newbie din sa car audio.
...recommended amp for seps (SQ)
