Results 1 to 9 of 9
May 3rd, 2006 11:20 PM #1
sirs,
what amps do you suggest for a beginner like me?
i need a 4way about 3K budget na medyo ok na performance n wala static
May 4th, 2006 12:34 AM #2Originally Posted by snker
ok na V12 tol. so-so performance, may sukli ka pa. as for the static, depende sa yan sa pag-iinstall. kung sablay, static talaga. read more about the audio set-up threads, marami ka mapupulot dun.
May 4th, 2006 01:39 AM #3Originally Posted by aceshark
May 4th, 2006 08:06 PM #4
mga sirs, i have a friend who recently bought v12, he followed tips seperating the power source and the rca, but unfortunately me static padin. he even added extra taping to the power for more insulation pero ganun pa din.
i'm starting to have doubts.
Driver/PasaHERO
- 1,310
May 9th, 2006 06:45 PM #5mahirap magtiwala sa V12 e...if you plan to upgrade din nman later, better invest on good amps. Kung wala tlaga, v12 tlaga ang bagsak
- Feb 2006
- 72
May 10th, 2006 12:29 PM #6brad try nyo muna ayusin yung RCA minsan maluwag at may loose contact.I had experienced that also before, nung binalik ko sa LA Accessories sabi nila HU ko daw ang may problema kesyo baka ampli din, but i do it myself and so far ok na ngayon sounds ko malinis na.
- May 2006
- 78
May 11th, 2006 01:21 AM #7Alpine amplifier V-12
Model NV-805
4/3/2 channels biridgeable
OK sa sounds malinis, narinig ko na ang set-up sa Ace hardware SM sta. rosa. Ito bibilhin ko pasok sa budget.
May 16th, 2006 04:46 AM #8
Mga chief, malaki ba ang difference ng 2000W sa 2500W na V12 AMP in terms of SQ? Medyo nakakalito kasi sa itsura, eto ung 2500W:
eto naman ung 2000W:
I got no info sa 2500W, pero sa 2000W, may Super Bass mode daw etc.. Wala bang option ung 2500W?Pero ba't mas maliit ung 2500W sa 2000W model? Pa-enlighten lang po. Tnx! =D
May 16th, 2006 06:29 AM #9
Nevermind... got an answer. Pang motor pa la ung isa. Stupid me... Sensya na po! =D
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
