Interesting ata yung mga Pioneer AVIC models...
Parang capacitive na yung screen vs resistive...
The reason why I opted with X595BT. Pero nung nakabit sa vios ko, may spacer nga na needed sa mga gilid unlike siguro sa mga 200mm units like AVIC na hindi na need ng spacers. Parang naliliitan pa pala ako sa 7inch na screen hehe.
AVIC also uses Papago for navigation. I wonder if it is as good as Waze or Google maps for PH use.
tanong lang po, nkabili ako AVH-185DVD then naglagay ako ng mp3 files and divx files, pero bakit isa lang ireread nyang format if una nya mababasa is mp3 - grayed out na ung mga divx files.
I tried to delete all the files, nilagay ko ulit ung divx and mp3 files - if mauuna nya mabasa ung divx format iggrayed out naman nya ung mp3 files.
Meron po bang kailangan iactivate na feature or ganito talaga etong model na ito?
Maraming salamat,
i think Pioneer headunits must be told what to look for when playing something. Like sa akin, I will select video so that the unit will scan all video files in the usb device. It it not like a pc that everything can be browsed in one go.
Parang may problem yung install ng X595BT ko. Mahina sagap ng FM/AM unlike nung stock. Naalala ko, nung nag pro program ng steering wheel controls sa vios yung installer, may error nung sinalpak na nya sa dash once the mode button is being pressed sa steering wheel. So ang ginawa nya, ginamit nya yung blue wire. Error was gone pero mahina radio reception ko. Nabasa ko online need yung blue wire na yung for amplified antenna. Any inputs para maayos ko ito? Ang trapik pabalik dun sa installer location.
mukhang yung blue wire sa harness nung antenna adaptor ay para sa antenna amplifier power. since hindi naikabit ng maayos, mahina sagap ng radio. lesson learned: buy your units and have it installed sa authorized centers. at least qualified yung mga installers nila.
ganito image nung antenna adapter: https://www.carid.com/images/america...tennas/ni6.jpg
Saw the price list on Lazada. Interesting products from Pioneer. Pioneer PH seems to be following up on Waze integration.
Is android auto supported on their top of the line Z and X models?
Hi guys I have an issue with my Pioneer avh-Z5050BT, calendar is very delay around 1-3pm sya nagpapalit ng day. Kahit itama mo next day hindi padin sya magpapalit tapos around 1-3pm magpapalit na sya ng day. Any thoughts about this? Time is okay.
My 595bt got defective after 4mos of being installed. Bigla na lang ayaw mag boot. Display lights ok naman. Waited for a month then nireplace daw ng supplier kasi sira daw motherboard. Hopefully all is good now. Worried lang ako pag nag lapse na warranty nito tapos masisira, magiging pang display na lang sya.
guys anong video converter gamit nyo para mag play yung mga video from youtube sa 2din natin? hirap mag experiment kasi time consuming.
Divx converter
Link below was a helpful read in getting the video specs right.
Playing videos in your Pioneer 2 14 Head Unit << advanxer.com
