Results 21 to 30 of 39
June 23rd, 2005 04:49 PM #21
ok ba yan pare? bgyan mo nga me ng estimate kung papainstall ako ampli ska sub or pwedeng ampli muna...sa ampli ba mag improve ba agad ung sounds ko? or kelangan palitan ung speaker kc bka nd nya kayanin ampli?
June 23rd, 2005 05:08 PM #22
Check mo yung speakers mo kung ilang ohms tsaka ilang watts ang kaya, RMS at peak. Based on that masasabi natin about powering them with amps. Pero sub + amp na lang muna since sabi mo ok naman ang speakers mo. Mga 25K puwede na, sama wiring, fuse, sub box tsaka simpleng install.
June 23rd, 2005 05:17 PM #24
Pre, Pricey yung DD, kung may makita kang 2nd hand baka pwede.
Amplifier naman kung tight budget ka, kuha ka ng V12.
June 23rd, 2005 06:15 PM #25Originally Posted by Field Master
Now if your music rarely hits below 50Hz, baka kaya na ng 6x9 sa likod yung lows... And some seps can play 80Hz with about the same level as higher frequencies, plus you can always adjust the gain for these frequencies if you have an EQ that can adjust those frequencies.
June 23rd, 2005 06:24 PM #26Originally Posted by Field Master
June 23rd, 2005 06:27 PM #27Originally Posted by ILuvDetailing
June 23rd, 2005 06:28 PM #28
Wildthing, ILD, thanks for your guidance. will get in touch with you when I upgrade my sounds.
June 23rd, 2005 06:33 PM #29Originally Posted by BlueBimmer
Xiaomi E-Car
