Results 11 to 16 of 16
- Jan 2008
- 26
April 18th, 2008 04:51 PM #12tnxs again for your replies and comments.
archie, yung amps hindi siguro 2000watts na out put nya, malamang PMPO lang yun. kaya ko lang na state na 2000watts kasi yun yung nakalagay sa casing nya. pero mosfet at 4way channel daw yun.
I will purchase it and install the amp and the 4 pcs Targa 2way in all doors plus the pioneer tweeter. I second stage ko na lang yung suggested nyo subs na 12", kausapin ko yung gumagawa ng videoke dito kung pwede makagawa ng sealed type baffles na kasya s likod ng sandalan ng pick up. Limited choice lang kasi dito unlike dyan sa mla madami pwede punthan para mag pagawa.
April 18th, 2008 05:02 PM #13
1 pair of 6.5" separates X-652C lang. no need for 2 pairs IMO ha? sabay mo na yung 12" sub para box na lang. good luck
April 18th, 2008 07:03 PM #14
sir if your considering the 4 speakers, rear and front doors... ok lang kahit yung seps sa harap lang power ng amp. yung sa likod, just let the hu drive those kasi pang rear feel lang naman yun. bridge mo na lang 2 ch sa seps and 2 ch sa subs.
sa box naman, AFAIK theres a calculation for those kung gaano kalaki dapat na size ng box.... sure you can fit the box sa likod ng sandalan but then can it maximize the boom boom?
- Jan 2008
- 26
April 29th, 2008 01:46 PM #15tnx sa lahat nag share ng opinions nila.
finished my sound set up for my pick up. installed a pair 0f 100watts crown tweeters on the dashboard, replace the front stock speakers with 100watts 2way Targa seps, 2 pcs 8"conzert for the subs(limited lng kasi space for baffles 5 1/2" x 12" x 15") and a v12 600watts 4 ch amp.
ang ginawa ng nag install drive the seps from the stock HU, then get a signal from the rear channel to the amp which is where the tweeters and subs are connected.
cost me around 7k all in all.
So far satisfied naman ako.
April 29th, 2008 03:06 PM #16
sir, for me mas maganda if ginamit yung 2 channels for the seps then the remaining channels for the sub. let the HU drive the tweeters nalang. maganda kasi ma amplify yung seps para mas magiging clear yung boses. just my 2 cents.
high idle RPM at engine start
