Results 1 to 8 of 8
- Jan 2004
- 79
March 31st, 2004 12:00 PM #1Hi mga master...
Saw this Rockford Fosgate Punch 301x Amp at US$120 sa www.ikesound.com... mura ba ito? plus around US$20 shipping papunta sa brother ko sa CA.
Wala pa akong setup, pero i want to build it up slowly... ok ba to start with this amp?...next will be the seps... currently, im using a Pioneer HU (1650 ata yun...di ko muna papalitan).
Need your expert opinion. Thanks!!!
- Jan 2004
- 79
March 31st, 2004 12:07 PM #2oooopsss...eto pala yun specs:
40 watts RMS x 4 at 4 ohms
75 watts RMS x 4 at 2 ohms
150 watts RMS x 2 bridged output at 4 ohms
2-, 3-, or 4-channel output
4-ohm stable in bridged mode
Tri-Way capable
front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
MOSFET power supply and output devices
Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
speaker- and preamp-level inputs
preamp outputs
worth it ba ito?? thanks!!!
March 31st, 2004 01:02 PM #3
Mahal talaga ang RF amps, but you get what you pay for. Winterpine yata ang exclusive distributor nyan dito locally. Mas makakasigurado ka kung dun mo tatanungin ang price sa kanila.
April 1st, 2004 12:27 AM #4
ok RF.... pero nabenta ko na akin.. kelangan pera eh.. pero reliable sobra and malakas.. laging under rated
April 1st, 2004 01:19 PM #8
It is under rated. May certificate na kasama yung akin mas malakas pa kesa sa normal ratings.
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
