Results 1 to 8 of 8
    Jan 2004
    Hi mga master...
    Saw this Rockford Fosgate Punch 301x Amp at US$120 sa www.ikesound.com... mura ba ito? plus around US$20 shipping papunta sa brother ko sa CA.
    Wala pa akong setup, pero i want to build it up slowly... ok ba to start with this amp?...next will be the seps... currently, im using a Pioneer HU (1650 ata yun...di ko muna papalitan).
    Need your expert opinion. Thanks!!!
    Jan 2004
    oooopsss...eto pala yun specs:
    40 watts RMS x 4 at 4 ohms
    75 watts RMS x 4 at 2 ohms
    150 watts RMS x 2 bridged output at 4 ohms
    2-, 3-, or 4-channel output
    4-ohm stable in bridged mode
    Tri-Way capable
    front and rear switchable high-pass (120 Hz, 12 dB/octave) and low-pass (80 Hz, 12 dB/octave) crossovers
    MOSFET power supply and output devices
    Maximum Efficiency Heat Sink Application (MEHSA) mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
    TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
    Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
    NOMAD — advanced protection circuitry for "intelligent" shutdown protection
    speaker- and preamp-level inputs
    preamp outputs
    worth it ba ito?? thanks!!!
    Mahal talaga ang RF amps, but you get what you pay for. Winterpine yata ang exclusive distributor nyan dito locally. Mas makakasigurado ka kung dun mo tatanungin ang price sa kanila.
    ok RF.... pero nabenta ko na akin.. kelangan pera eh.. pero reliable sobra and malakas.. laging under rated
    over rated? or under rated?
    Signature
    underrated.
    pasensya po.. tao lang. nagkakamali. hehehehe
    It is under rated. May certificate na kasama yung akin mas malakas pa kesa sa normal ratings.
need your input on Rockford Fosgate Amp
