Results 1 to 5 of 5
    Feb 2007
    tulong naman kng paanu patunugin ng ok ung seps ko. soundstream, kaso lng na lagay sya sa side door ng mazda 32 '94 model. may lagay ka ba sa likod ng seps before screwing it to the door? parang round hard palstic na cover sa likod ng speaker para tumonog ng bilog sa mid bass, ksi parang lata ung tunog. may crossover naman ako d talaga ma tuno
    Jun 2006
    The plastic thing is a spacer. There are 2 uses. 1 is to allow more room for the magnet, I belive you have 5.25 inchers, I doubt that you need to create more space. The other use is to get better sealing between the speaker and the door. Think of it like a gasket. Although, carpet or a real gasket will work better than plastic.
    To get better sound, tune your amp and play around with your HU and Xover settings. Make sure your amp can supply your speaker with enough power. You can upgrade to a 6.5 inch. Or get your doors sound deadened.
    Feb 2007
    yan anu ba yan ung deadened? sorry ksi bago lng ako dito
    Jun 2006
    sound deadening is the process of applying dampening material to your cars surfaces ie doors, floors etc.. to make them vibrate less. You can use branded imported materials like dynamat or local materials like flashband.
    Materials available at car audio shops. Flashband from your favorite hardware store. Effect is that less sound enters your cars cabin and mas buo ang midbass.
    Feb 2007
    ah ok. important pala to sa sasakyan ko. thanks alot bro! ths wud make a big differenc.
help sa install ng seps
