baka may alam kyo jan na murang amp pra ma drive ung l7 na kicker na 1000 rms. thanks!![]()
Not too many amps could drive a sub w/ 1000 RMS. Your only options is to get the MTX-TA Super Amplifier that could pump out 4000 watts in 4 ohms load and 6000 watts in 2 ohms loads.
By the way, are you sure that MTX is 17 inch sub? The super subs on MTX is 15 inch unless you have the JACK HAMMER MTX sub but, this one is 22 inch and a 369 lbs, 6000 watt RMS w/ 12,000 watt music power.
search for 2nd hand items. baka makaswerte kang may nagbebenta for around 10k.
L7 paps? naku madugo yan, kung tinipid mo ang power niyan di tutunog ng mabuti yan, ang the best amp na ilagay mo diyan is mono amp! at proper box kaboom
HIFONICS amp ang branded at cheapest na naiisip ko nasa 12K-20K more or less
good luck sa project
