Results 1 to 5 of 5
- Feb 2007
- 48
July 29th, 2007 11:58 PM #1tulong naman kng paanu patunugin ng ok ung seps ko. soundstream, kaso lng na lagay sya sa side door ng mazda 32 '94 model. may lagay ka ba sa likod ng seps before screwing it to the door? parang round hard palstic na cover sa likod ng speaker para tumonog ng bilog sa mid bass, ksi parang lata ung tunog. may crossover naman ako d talaga ma tuno
Tsikot Member Rank 4
- Jun 2006
- 2,605
July 30th, 2007 08:02 AM #2The plastic thing is a spacer. There are 2 uses. 1 is to allow more room for the magnet, I belive you have 5.25 inchers, I doubt that you need to create more space. The other use is to get better sealing between the speaker and the door. Think of it like a gasket. Although, carpet or a real gasket will work better than plastic.
To get better sound, tune your amp and play around with your HU and Xover settings. Make sure your amp can supply your speaker with enough power. You can upgrade to a 6.5 inch. Or get your doors sound deadened.Last edited by userfriendly; July 30th, 2007 at 08:09 AM. Reason: correction
- Feb 2007
- 48
- Jun 2006
- 2,605
July 30th, 2007 06:25 PM #4sound deadening is the process of applying dampening material to your cars surfaces ie doors, floors etc.. to make them vibrate less. You can use branded imported materials like dynamat or local materials like flashband.
Materials available at car audio shops. Flashband from your favorite hardware store. Effect is that less sound enters your cars cabin and mas buo ang midbass.
- Feb 2007
- 48
July 30th, 2007 09:21 PM #5ah ok. important pala to sa sasakyan ko. thanks alot bro! ths wud make a big differenc.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
