Results 11 to 20 of 43
- Jun 2006
- 19
June 3rd, 2006 06:39 PM #12sir detailing,
meron po kasi ako nakikita sa market ang brand is v12? ok din po ba yun?
hindi po kasi ganun ka expensive wheels ko kaya ok lang sakin bata tumunog lang ng maganda.
Ride Safely!
- May 2006
- 78
June 3rd, 2006 09:00 PM #13Originally Posted by jomed
- Jun 2006
- 19
June 3rd, 2006 09:12 PM #14Originally Posted by jezreel
plano ko po kasi 2 subs gamitin ko. does it mean 2 ampli din gamitin ko???
tia
- May 2006
- 78
June 4th, 2006 01:33 AM #15Originally Posted by jomed
June 4th, 2006 02:03 AM #16
mga bossing, meron pong V12 na orig (from Alpine), at V12 na fake >> made in China. Price range of the fake V12 is around 2.5K to around 5K depending on the model. Orig V12 range from 10K and up. Sa orig na Alpine V12 engraved yung "V12", sa fake, printed lang.
Here's a sample of the original Alpine V12
Sample of a fake V12
Don't get me wrong fake V12's aren't bad. Dun din ako nagsimula, there great bang for the buck amps but if you can't go wrong with the original stuff.
- Feb 2006
- 14
June 4th, 2006 03:43 AM #17Originally Posted by aceshark
June 4th, 2006 09:08 AM #19
I don't know what capacitor type that is, but I think the work of the capacitor used for the sound system is that it stores power when there is a big need of electricity needed by the amp like when there is a big bass sound the battery cannot supply the required electricity the capacitor will fill in for the need, then it will recharge itself using the battery waiting for the next need of the amps. parang reservior ang trabaho nya.
a four channel v12 amp can power na your front speakers and subs. there are different types of v12 na fakes, just make sure that may warranty ang dealer.
but sa 30k budget and may existing HU ka na, I suggest DLS classic 8k, EFX amp 12k Kicker comp sub 6K with box and wiring kit 1k may sukli pa.
June 4th, 2006 09:57 AM #20
you dont NEED a capacitor if your system only puts out enough wattage to power a single sub...as long as your electrical system is in good condition. a capacitor will help, but the thread starter mentioned that he's on a tight budget, so there are better uses for the money than capacitors...
...like getting something better than 6x9 speakers. just dont do it. kung hindi pasok sa budget yung separates, put your plans on hold and save up more money. there is a HUGE difference. the only thing i would even think about using 6x9's for is for rear fill (kung may separates ka na sa harap at may sub sa trunk...you can put either 6x9's (or preferably coaxials) in the rear speaker board just to fill out the soundstage.
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
