Results 1 to 9 of 9
- Aug 2013
- 22
May 30th, 2014 06:46 PM #1i bought a kicker bass station 8". Sa ampli niya sa Gilid may input level, phase, gain, x-over, bass boost gusto ko patunugin ng maganda. Baka may mga inputs kayo ng tamang timpla saka anu mga meaning ng mga settings na yan. salamat!
- Jan 2007
- 187
- Oct 2009
- 2,271
May 31st, 2014 02:53 PM #3gain, x-over, bass boost
gain yan ung pinaka volume niya.dyan mo titimplahin ang eksaktong lakas ng buga.ng ampli.
x-over dyan mo pag hihiwalayin ung kalansing.boses,ang baho..kalabog, bass
bass boost pag sinelect mo yan auto matic lalaks ung bass puro bass lang..
June 1st, 2014 12:50 PM #4
Gain is not a volume control. It is likened to a flood gate to match the input voltage.
Crossover separates the sound frequencies. Think of them as a sound filter.
Bass boost throws a +x dB on a range of bass frequencies so to "enhance" them.
June 1st, 2014 04:46 PM #5
*jhnkvn
Ano kailangan ko adjust sa ampli or sa headunit para gumanda tunog ng bass. Ang gusto ko kasi na bass yung gumagapang at hindi yung matigas na bass. Yung para bang nageecho yung bass. Thanks in advance.
I may be stupid, but I am not a fool.
June 2nd, 2014 01:58 AM #6
Lots of factors really.. but gapang is just ample volume around the 40hz-50hz region. Because of the extremely low frequencies, the best way on how to get "gapang" is to construct your subwoofer's box for it rather than dinadaan sa tuning.
Matigas ang bass is because it's being cut-off'ed via crossovers or that there's not enough decibels on the low bass end which is why you can't hear it. For example, it's fruitless to get "gapang" out of a 80hz cutoff from a typical 2-way seps because by the time it hits the 40hz region, sobrang hina na niya.
If you have a subwoofer, madami factors dyan actually.. which head unit? which subwoofer? how is the box constructed? For one, just try boosting the 40hz on your graphic/parametric EQ and increase subwoofer level by an amount you think is good.
Gapang.. is really the result of good-enough output at a certain frequency and you need to have a song that hits that low too.
June 2nd, 2014 05:33 PM #7
i had the 10 inch version a while back but dont remember much regarding the setting. i think i set the car bass to zero then played around with the phase (like a reverse), gain, and bass level on the knob. i remember leaving the car stereo bass setting at 1 with my final settings then bump it up along with the bass level knob when needed.
- Aug 2013
- 22
June 5th, 2014 06:42 AM #9
if i got it right, it is the cutoff on the lows that the sub will play. i just checked mine in storage and i have the following setting for an infiniti fx (similar interior dimension for 1st gen murano)input: lo, phase 180, gain 2nd line, x-over 50hz, bass boost 8, which i think is bypassed by the remote bass. this makes it tight and punchy and not boomy kind of bass.
your's im sure will be different. i suggest start the x-over at 50hz and experiment. have fun playing with it.
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
