Results 1 to 10 of 14
Tsikot Member Rank 3
- Nov 2002
- 1,757
April 1st, 2009 04:52 PM #1ano ba dapat icheck ko?
ganito kasi, pagmatagal na kong nasa daan, nagloloko yung radio ko. bigla na lang nagkaka humming sound na lumalakas pag tumataas rpm or bumibilis takbo. then may mga parang static, yung tipong sound ng nagsspark na wire, pero galing sa speakers. pag in-off ko yung radio, wala nang mga tunog. pero pag on ko uli, andun na naman. pagnapahinga na yung sasakyan (off engine), pag start uli, nawawala naman yung abnormality. ano kaya ito?
TIA
- Apr 2008
- 188
April 1st, 2009 06:17 PM #2Static sound yun sir, ganyan din sakin dati. newly installed ba ang sound system mo?
April 1st, 2009 06:49 PM #3
may ganyan ding sound yung sentra namin dati. ang narinig ko lang sa papa ko, static sound nga raw. pero nabenta na kaya hindi ko alam kung paano na-solve, or pinabayaan nalang ng buyer.
April 1st, 2009 07:24 PM #4
Its coming from your radio. Try to ground properly your radio.
Separate your signal wires from power wires.
April 1st, 2009 09:52 PM #5
- Nov 2002
- 1,757
April 1st, 2009 10:53 PM #6how do I know which is the ground wire? I'll try to trace the power and signal wires to check if there's contact.
wala naman akong pinuplug na kahit ano sa cigarette lighter. during daytime radio at aircon lang naka on. ang weird nga kasi pagmatagal na kong umaandar lang sya nangyayari.
hindi sir. lumang luma na (11 yrs). I think stock pa sya save for 2 additional speakers sa rear na tinanggal din ng dating owner. simpleng HU + 2 front door mounted speakers + cd changer lang ang setup.
thanks for the replies guys! keep em comin'!
- Apr 2008
- 188
April 2nd, 2009 10:49 AM #7
- Apr 2009
- 15
April 6th, 2009 08:19 AM #8Minsan kailangan lang kabitan ng relay mawawala na iyon. May kaibigan ako nakabili sa Blade ng grounding kit. Nakatulong din iyon.
April 9th, 2009 07:01 AM #9
sir...try nyo na mas malaking gauge ng wire sa negative and bolt nyo sa body ng oto. lihahin nyo muna ung surface bago i-bolt para malakas contact.
April 14th, 2009 01:43 PM #10
hmmm para syang alternator noise.. usually nangyayari sya pag magkadikit yung power cable and RCA (signal cable) ng amplifier..
try to fix or unclutter your radio wires baka nagkadikit dikit na kung wala naman po kayong nakakabit na amp.. HTH
Suzuki JIMNY [merged threads]
