Results 11 to 14 of 14
May 20th, 2009 11:34 AM #11
This is my current issue. Almost 2 years na yung subs ko w/ just the V12 amp no problem.
Now tinanggal ko yung subs sa trunk with the ground wire.
Nung binalik ko na, nagkaroon na ako ng huming sound.
Same connections din naman before I removed it.
I guess this has to do something with power when its humming with the rpm.
Anybody has a solution?
I guess I'll try another ground location.
Tsikot Member Rank 3
- Nov 2002
- 1,757
May 20th, 2009 12:18 PM #12*simpsonseclaire,
yung sayo ba lagi syang naghuhum? yung pagka-on palang? yung sa akin kasi wierd e. naghuhum lang sya pagmatagal na syang naka-on, let's say more than an hour na umaandar ako or kung sobrang taas ng araw. so i guess connected sa heat.
May 23rd, 2009 06:58 PM #13
- May 2009
- 1
May 25th, 2009 09:03 PM #141 of the many solution(s):
1. baklasin nyo hu nyo, pero yung harness at rca sa likod wag nyo tanggalin
2. kuha kayo any metal like screw driver, etc.
3. paandarin ang kotse, i-on ang radyo
4. idikit nyo yung screw driver sa body ng hu at sa ground ng rca
5. then, i-rev nyo auto
pag nawala, ang humming, pacheck nyo na hu nyo, walang ground yung rca out ng oto nyo.
pag may humming pa rin, check nyo rca and all cables
pag ok naman ang connections, pa-check nyo na ampli nyo or subukan nyo mag try ng ibang ampli. pag nawala humming, ayun, ampli nyo may problem
--baka makatulong sa inyo to--
pag di nyo alam, patulong kayo sa technician.
high idle RPM at engine start
