Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Guys i have this problem here. My system was tuned by my installer according to my preference. Then yesterday my batt went dead and nareset yung settings. Di ko ginagalaw yung settings na yun kasi satisfied na ako pati yung amp. Any suggestions how to tune a 7450 and a Fenton 41000 amp? Like if you can give setting examples and how to tweak my amp. SQ na may konti bayo sana. Thanks tsikoteers!
    di naman ata mag-iiba settings sa amp mo pag naubusan ka ng batt. HU settings lang ang mabubura. badtrip yan bro, same thing happened to me when i had my timing belt replaced, tinanggal nila yung connection sa battery terminals to be safe. kapain mo nalang ulit, and if it sounds good, save those settings! yan yung ginawa ko :D
    bad trip nga bro sobra! Kinapa ko lang pero parang may kulang.. haaayy. tagal pa bago ako makadaan kina rocky kasi. Uwi ko muna auto ko Tarlac baka sa march ko pa madadala.
  4. #4
    di ba nakaset na yung gain, HPF, LPF settings sa amp?
    Jan 2003
    When I tune, I usually do it in the evening and in a dark place. Then I close my eyes and "feel" what is missing in my favorite tunes.
    Feb 2005
    Bro yung loud settings mo baka di naka set sa high and yung Equalizer setting mo di mo na set sa gusto mo baka naka set yan sa powerful before or super bass. Ang settings ng dalawang yan ang try mo laruin. Yung am naman di nag bagbago ang settings niyan.
    mahirap nga yan. nagpapatono din ako, pero pag dating sa iba't ibang music, hindi maganda ang tunog ng seps ko. so, pinapalit palitan ko ung settings.
    den, ayun, nawawala ko den.
    pero ngayon, mejo kabisado ko na HU ko.
  8. #8
    dapat may orig cd ka... one is for base, one for clarity. set the gains for the subs then tune for the seps.
    setting po ng HU po ung nareset...
    Jan 2003
    hows the best way to set your HU? for subs then seps muna or pano? tingin ko kung ano ang madalas na pakinggan mo na music dun mo iseset.
    Pioneer yan diba? try mo to posted at HCP:
    how to configure the qfactor settings: (thanks to n0y)
    press and hold audio then lalabas na yung qfactor
    dun sa low freq: 40-80-100-160 dapat nka 2w
    dun sa mid freq: 200-500-1k-2k dapat naka 1w
    dun sa high freq: 3.15k-8k-10k-12.5k dapat naka 2n
    ...hello! sana this would help
    LOW: 40-80-100-160
    MID: 200-500-1k-2k
    HIGH: 3.5k-8k-10k-12.5k
    settings ng LOW, if may sub kayo ilaro nyo na lang sa 100 or sa 160 ang freq and set it to 2W, if walang sub ilaro nyo sa 40 or 80 and 2W pa rin
    settings ng MID, put it sa 200 then 1W
    settings ng HIGH, put it sa 12.5k then 2N
    pag gusto mo konting bayo adjust mo yung gain sa amp mo for your subs. Yung HPF naman ng HU mo set mo sa 50hz para may midbass ng konti
    uy very useful post! ma-print konga :D
    Jan 2003
    very useful! ma try nga sa auto ng utol ko
    nasubukan ko yung Q factor settings na yan sa 7650 ko gumanda nga :D lumitaw lalo yung boses.
    Nakasave na yan sa phone ko para in case tanggal battery madali lang i-set ulit :D
  15. #15
    Wow oks pala yung Pioneer HU. Daming settings.
    mas tweakable pa jan ung mga hi-end.
    kahit ako, di ko ma-ayos ung ganyan ko nung naka-up6 ako e.
    yep yung mga hi end meron pa time alignment :D
  18. #18
    time alignment? panu yun?
    Auto Time Alignment
    Pioneer's innovative Auto Time Alignment automatically shifts the soundstage in front of the listeners, bringing out the vocals in the process, to create the optimal in-car reproduction of your music. Using the included microphone, it estimates the delay from each speaker to the listening position and adjusts the speaker sound output timing accordingly. The output timing for each speaker is adjusted precisely so that the sound from each speaker, wherever it is installed, reaches the driver's ears at the same time, thus optimizing the listening experience.
    :D
    http://www.pioneerelectronics.com/pn...891896,00.html
  20. #20
    thanks for the info, basahin ko mamaya.
Help in tuning my system
