Results 11 to 20 of 28
February 28th, 2005 12:33 PM #11
Pioneer yan diba? try mo to posted at HCP:
how to configure the qfactor settings: (thanks to n0y)
press and hold audio then lalabas na yung qfactor
dun sa low freq: 40-80-100-160 dapat nka 2w
dun sa mid freq: 200-500-1k-2k dapat naka 1w
dun sa high freq: 3.15k-8k-10k-12.5k dapat naka 2n...hello! sana this would help
LOW: 40-80-100-160
MID: 200-500-1k-2k
HIGH: 3.5k-8k-10k-12.5k
settings ng LOW, if may sub kayo ilaro nyo na lang sa 100 or sa 160 ang freq and set it to 2W, if walang sub ilaro nyo sa 40 or 80 and 2W pa rin
settings ng MID, put it sa 200 then 1W
settings ng HIGH, put it sa 12.5k then 2N
February 28th, 2005 06:05 PM #14
nasubukan ko yung Q factor settings na yan sa 7650 ko gumanda nga :D lumitaw lalo yung boses.
Nakasave na yan sa phone ko para in case tanggal battery madali lang i-set ulit :D
February 28th, 2005 10:29 PM #16
mas tweakable pa jan ung mga hi-end.
kahit ako, di ko ma-ayos ung ganyan ko nung naka-up6 ako e.
March 1st, 2005 08:04 PM #19Auto Time Alignment
Pioneer's innovative Auto Time Alignment automatically shifts the soundstage in front of the listeners, bringing out the vocals in the process, to create the optimal in-car reproduction of your music. Using the included microphone, it estimates the delay from each speaker to the listening position and adjusts the speaker sound output timing accordingly. The output timing for each speaker is adjusted precisely so that the sound from each speaker, wherever it is installed, reaches the driver's ears at the same time, thus optimizing the listening experience.
http://www.pioneerelectronics.com/pn...891896,00.html
The ₱613,000 discount is until June 31, 2024. Note that the Peugeot 5008 used to retail over 3M...
2018 Peugeot 5008
