Results 1 to 20 of 22
    Sep 2005
    In that case, you better check the integrity of the cable with an ohmmeter, testing for continuity from tip to tip, and for any shorts.
    You can also try turning off any sound enhancement feature of the HU and see what happens.
    Nov 2007
    i experience this a lot. its usually loose lang. i just got a new cable then ok na. but ang galing nga nyan minsan eh. klarong klaro yung backup vocals.
    Dec 2007
    Probably polarity issues. Maaring may cancellation.
    revive ko lang tong thread na to...i just recently purchased a pioneer 2950 myself, 2nd hand of course. just noticed that the music played through my mp3 player(aux-in), samsung k3, is not as loud as compared to a cd. the player uses the 3-pole jack, i checked...i've yet to notice missing instruments though. is it really like that ba...? music is not as loud played through the aux-in...TIA
    so far the volume is ok when I play mp3 through the aux-in...just some missing instuments on some songs.
    try fixing the equalizer/settings of your mp3 player. Also try using different baby jack connections just to see if the problem is with your cable.
    Quote Originally Posted by happymeal18 View Post
    the player is at normal playing mode...at its highest volume it still does not compare to the loudness from the cd player. to give ya'll an idea, to satisfy my ears, from he aux-in i set the HU volume to around 35-41 maybe...but through the cd player i'm satisfied with the HU volume at just around 18-24. will try to buy another 3.5mm jack...i just bought mine in ace hardware at just 65Php. hehe...medyo kuripot kasi ak eh.
    Apr 2008
    Quote Originally Posted by jumpman138 View Post
    sir naka-high na ba nun ang volume ng MP3 player mo?
    Feb 2006
    sir, i also had the same cable sa ace hardware and experienced similar results. when i changed to a higher quality cable, it turned out ok. ang comment sa akin when i inquired about it is that the wiring of the php 65 cable manipis daw to the point that it affects the output quality
Help... missing sounds while playing mp3 through aux
