Results 1 to 5 of 5
    Oct 2013
    Good day po. pinalitan ko kase ung headunit(limot ko name pero galing japan) at speaker (pioneer ung tig 1099) ng Kia picanto ko. problema pag above 17 ang volume. nagkakaroon siya ng parang static na tunog. hindi ko alam baket. mapa radio o aux. any idea pano po mawala un? kase ung try name ung speaker dun sa blade ok naman umaabot ng 30 ung volume na walang problema
    Most amp impedance have wide range 4-16 ohms, pero just in case check mo na rin kung match ang amp sa speakers. Nakasulat sa manual or body ng HU ang impedance same with speakers.
    Tsek mo din grounding, dapat separate grounding ng speakers mo hindi yung nakakbit lang sa chassis.
    Kung na-isolate mo na yung dalawang nabanggit at ganun pa rin, mag kadkad ka ng temporary speaker wires going to the speakers. Possible kasi na may unwanted inductance or attenuation dahil sa noise or yung gauge ng wire insufficient to carry the current.
    Oct 2013
    I pacheck ko nalang sa mismo nag kakabit ng audio. mahirap kase onti gamit ko dito.. magkano kaya pag gnon?
    Aug 2010
    You got a full-sized keyboard sa harap mo. I'd say better use it. I'm not a fan of text speak in the forums after all.
    2) You are to post replies legibly.
    SMS shorcuts and randomly alphabetized characters are strictly not allowed. The use of webcuts, however, are acceptable.
    It will be hard to accurately assess kung ano kilangan mo when you are unsure of your problems. Static ba problema mo? Maybe a high floor noise? You cannot simply compare speakers and head units of different brands and makes -- they all measure differently.
    Tama lang yun ginawa mo: tell it to your installer. Magkano? Just claim that they installed it improperly.. looks like it to me.
    hi there! Meron na po bang nagpalit nang stock speakers nang toyota super Grandia, if yes ano pong size ang speakers for front and rear. Thanks!
Question po about car speakers.
