Results 11 to 20 of 20
July 19th, 2013 09:22 PM #11
Kung ayaw mong magkatungkab yung dashboard mo, iblack list mo na ang candyshop. Namomoblema ako ngayon kung saan ko pwede ipaayos yung mga tungkab around my stereo panel.
- May 2013
- 23
August 10th, 2013 11:09 PM #12Any suggestions on what amp and loc should i get to match this
Seps - Polk Audio DB6501 6.5-Inch 2-Way Component System
Sub - Pioneer TS-WX110A (the sub has a built in amp)
Loc - AudioControl - LC6i 6channel or LC2i - Audiocontrol 2-channel
Amp - ?
August 11th, 2013 03:49 AM #13
How much are you paying for the Pioneer subwoofer? If it's anything above 4,000php, you're paying a lot of money and I wouldn't recommend it on a bang-per-performance basis.
Rather than buy a LOC or line out converter, just try to pick an amplifier that readily accepts high-level or speaker-level connections. It's harder to find compared to RCA-ready amplifiers but at least you save a few bucks down the road.
An example would be Rockford's newer Punch BRT amplifiers ([ame=http://www.amazon.com/Rockford-Fosgate-PBR300X4-4-Channel-Amplifier/dp/B004T163SY]Amazon.com: Rockford Fosgate PBR300X4 Punch BRT 300-Watt Ultra Compact 4-Channel Amplifier: Car Electronics[/ame]). They're extremely small thanks to Class D topologies so you're looking at a the size of a single DVD case. Problem is, Rockfords are expensive here in the Philippines thanks to prohibitive shipping and tax laws. This is also why US-based JL Audio is expensive here. You're generally looking at the Amazon US price if you click that link. However, the prices go for sub Php14,000 in the Philippines.
- May 2013
- 23
August 11th, 2013 10:47 PM #14wow thats a big difference in price..
i havent bought it yet.. 7,000 is the price they gave me for the Pioneer TS-WX110A.
What i like about it is that its thin enough to fit under the front seat.
i thought LOC is need if you are retaining the stock head unit.
August 11th, 2013 11:52 PM #15
You're paying too much for space-savings. The rule of building subwoofers is simply easy.. you get three choices: (1) bass extension (2) efficiency (3) space-saving. And you can only get two of those. The more knowledgable ones would feel that it's a waste of cash. If you're going to get a compact underseat sub, you're better off simply running the midbass without a high-pass filter.
I understand that you need space but a 1 cubic feet box isn't huge at all -- it fits quite nicely sa front passenger seat mo while still having sufficient legroom. For 7k, you can easily buy off a 3k subwoofer driver and spend the rest (and have change) for the box. Of course if you're consulting somebody who has stocks of the Pioneer, they'll happily push you for the purchase. A sale's a sale.
A line out converter isn't magic. What it does is convert speaker level output/line-level output/high-level output into low-level signals (RCAs). Why is the signal called high? It's because speaker level connections carry voltage and current. RCAs or low-level signals on the otherhand simply carry voltage which you then send to your amplifier. The amplifier then amplifies the voltage in its pre-amplifier stage (hence the gain knob), adds current in the power-amplifier stage.. and voila... you are now sending speaker-level connections again to your speaker.
An amplifier that accepts speaker-level inputs simply means you're "skipping" a step. They're harder to find as most amplifiers accept only RCAs though.
At the very least, leave the subwoofer out of the equation and throw it in once your system is "finished" and you feel it's inadequate. Getting bass inside a car isn't hard at all.
- May 2013
- 23
August 13th, 2013 03:16 PM #16thank you very much sir..
ive tried inquiring about the rockford fosgate sa bombay na supplier kaso wala sila.
do you know a much cheaper amp that accepts speaker level connection?
August 13th, 2013 08:41 PM #17
- May 2013
- 23
- May 2013
- 23
high idle RPM at engine start
