Results 11 to 17 of 17
- Nov 2004
- 20
May 28th, 2009 09:30 PM #11noted, sir. mukhang mahaba-habang trabaho nga lang ang gagawin ko para i-rename yung files by the way, i'm using a jvc avx810
looks like deleting some folders worked. lumabas na yung folders from "A" to "P"...am still choosing kung alin ang iiwanan ko sa hdd na selected folders.
May 29th, 2009 11:57 AM #12
- Jan 2008
- 337
May 29th, 2009 02:30 PM #13I have avx814, maybe our specs are he same for this model series. From maual it says it can recognize 5000files, 250folders(999files per folder max), max of 25-character for folder names.
Also try scanning user-manual. Hope this helps.
- Jan 2008
- 337
May 29th, 2009 02:30 PM #14I have avx814, maybe our specs are the same for this model series. From maual it says it can recognize 5000files, 250folders(999files per folder max), max of 25-character for folder names. Also try scanning user-manual. Hope this helps.
May 29th, 2009 02:42 PM #15
check mo din mga file names ng mga music files mo sir, as per experience ko po kasi, di din nia mabasa kung mahaba-haba ung file name ng file
- Oct 2008
- 944
May 29th, 2009 03:08 PM #16panong hdd ba? as in yung drive mismo o sealed katulad nung wd passport? kasi mga ganyang mga disk e dapat may supply ng power na 5w+ to work, kasi hindi lang siya basta basta usb just like any flash drives eh.. passports need 5w+ na kinukuha niya rin directly kung san siya sinalpak so does your HU give power sa mga nakasalpak sa kanya o does it only read?
- Nov 2004
- 20
May 29th, 2009 04:14 PM #17*burai
sir, it's a wd passport 160gb hdd. it can read the folders and play the music, pero hindi lahat ng nilagay ko lumalabas.
*jatcos
yes pareho nga ng specs pero i'm sure di ako umabot ng 250 folders and ang largest number of files ko in 1 folder is a little less than 400.
*cc18352
short na yung names, sir. e.g. one folder is titled "sweet soul" with about 25 songs in it...isa ito sa hindi makitang folder. even the file names are limited to the song title only. nevertheless, i will double check
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
