Results 21 to 28 of 28
- Nov 2008
- 123
July 13th, 2009 03:03 PM #21Mapakinabangan mo rin po sir..pero sa isang battery you need to consider hindi lang ang sound sytem mo ang gumagamit..pag naset-up mo na try magstandy and listen outside your car..I can assure (100%) your system will not last..( iba rin kasi if your system has alot of current and can play all night long mas enjoy mo yong pinagpaguran mo)..IMHO sir huwag ka mag Install ng maraming SUB sir dahil masefficient ang sa isa pag na sa exact or properly design enclosure..
Yong battery po luckily meron pa kaming konting space sa tagiliran ng box..meron naman ngayon na maliit lang ang bettery pero may malaki ang capacity..
ito po ang harap or pinto ng system ko sir..straight JBL po yan I have Six pairs of 6.5 coax(another pair at the back passenger door) and a pair of JBL CS 10" threeways..these are all powered by my 75.4 GTO JBL(basta sakto sa load lang po)..almost 4 years na itong humahataw.. I can really say to you kung gaano katibay ang JBL..(invest a good/quality brand isang beses lang po ang gastos ninyo... I learned from my mistakes..LOL)
- Jun 2009
- 16
July 13th, 2009 08:13 PM #22
July 14th, 2009 12:19 AM #23
Sure! Coming from Manila City Hall, just take the right flyover heading to Recto. After the flyover, you should see LRT1 on your right, traverse the road under LRT1 and in less than 300m, there should be a PS BANK branch on your right. Turn right on the street after it and go straight. In less than 200m you should see MOSES AARON and PAUL VINCENT on your left. HTH
EDIT: Via commute naman, here's a more street-detailed description:
1. Baba ng LRT Carriedo Station
2. Lakad heading to Recto
3. First street should be Ronquillo on your right
4. Second street will be G.Puyat (where you'll see the PSBANK)
5. Enter that street and there should be a street on your left called Trinidad.
6. Just go straight, and after passing the Trinidad marker, or more or less two/three shops after that street is MOSES AARON ELECTRONICS on your left.Last edited by batang_raon14; July 14th, 2009 at 12:27 AM.
- Nov 2008
- 123
July 14th, 2009 03:30 AM #24If your sub is only a single 4ohm your amp will provide that 1200watts but if your sub is a dual 4ohms coil..wire it into parallel (+)(+) and (-)(-) your amp will see a 2ohm load..and will porovide a 1500watts of power(750 each coil)..
Try this site..it has more detailed info. it will help you the basics..
http://www.diyaudioandvideo.com/FAQ/Wiring/
- Jun 2009
- 16
July 14th, 2009 12:08 PM #25tnx batang raon, Ill try to check them out soon.
*Xtian, how about pag sabi 1 ohm lang? kasi yung sinabi sakin na sound magus x1502, 1 ohm lang daw. so if ever ito nabili ko hindi nya kayang bayuhin yung GT5-12 kasi 4 ohms, ganun ba yun bro?
- Nov 2008
- 123
July 14th, 2009 05:43 PM #26
Hindi po ganyan sir ang conpcept..if your talking about resistance or load para sa amp mo..
ito na lang...baligtad po ang value sa resistance..kung mataas (eg. 4ohms-8ohms) tapos yong amp mo pwidi niya tatanggapin ang 1ohm(stable 1ohm) ibig sabihin po ang 4oms or 8ohms ay magaan para sa kanya edrive.. the lesser the value (1-2ohms) ibig sabihin po medyo mabigat, so kung mabigat ang amp will do more efforts(power) para madrive niya ang sub/s...
Maganda po sir kung malalaman mo ang basics ng Parallel/Series speaker wirng dahil pwidi mo po mapaglaroan ang amps mo..kahit gaano karami ang speakers basta mapapalabas mo sa recommended load walng prolema po..
ang JBL po sir ay 2ohms stable..so walang problema ang 4ohms mo..
- Jun 2009
- 16
July 14th, 2009 07:28 PM #27hehe... tnx bro mejo di ko alam mga terms na ganyan e. anyway ang sakin lang nman i just want to make sure na pag kinonekta ko na yung gt5 sa 14001 neither of them will give up nor get burned. kaya mejo iniisnab ko ang sound magus x1502 kasi sabi 1 ohm. akala ko mahirapan ang 4 or 8 ohms na sub.
ok another query if you dont mind bro, paano ko ikokonek yung sub sa amp? basta na lang ba tap sa (+) at (-) lang ng amp? di ba 2 channels lang ang 14001?
- Nov 2008
- 123
July 15th, 2009 06:55 AM #28Sir sa pagcoconect you need to be careful dahil amps were not made the same..always base your connections sa manual...
yong JBL 1400.1 po sir ay single/mono amp po yan..yong nakikita mo na apat na connections (+)(-)(-)(+) sa loob po ay pinag-isa yan..
eg. if you have two 4 ohms subs tapos gagamitin mo lahat na terminal.. 2ohms po yan dahil sa loob ng JBL1400.1 naka parallel po yan...kung sa 1400.1 tap mo lang sa magkatapat na (+)(-)
About sa sound magus wala po akong maitutulong sa iyo dahil hindi ko alam ang brand nyan pero sa specifications maganda siya..(Hopefully meron maka bigay ng feedback about sa brand na ito..yan kung hindi ka nagmamadali)
high idle RPM at engine start
